dfndr
I was looking on ebay for socket set to use on Brit bike. I searched for "Whitworth" and there was a German set that came up but it said "AF". Is this the same? Thanks
I asked this a few months back during a discussion of European tools. On of the members from Britain said it meant "Across Flats" meaning it is sized SAE fractional.
Whitworth tools are marked with a fractional size like 9/16 followed by a W. The size being the size of the stud that the nut is screwed onto.
If you are referring to the Gedore 1/2 drive socket set, it goes from 7/16 to 1" AF. 1" in whitworth would be huge. You can judge from the size of the 1/2 square drive, the 1" socket is indeed about one inch across. I think the seller is mis-using the term Whitworth.
www.samstagsales.com (located here in the US) is one source of European made tools, including Whitworth sized tools.
Charles
Just got a whitworth socket in a lot of sockets i just picked up. (Didn't want to open a new thread)
Unless you have a 1960s British sports car or bike does anyone use (or want) Whitworth now?
[...] does anyone use (or want) Whitworth now?
Apparently so, because Ko-ken makes a surprisingly wide variety of Whitworth sockets: 6- and 12-point, standard and deep, and even swivel.
Even more surprisingly, Palmac apparently has all of them in stock.
They show up on other stuff, too. Pre-war machine tools, airplanes, etc, a number of which are still around. Also, nearly everyone I know who bought a first british car in the last decade or so went out and bought a bunch of whitworth tools, and they're not terribly price sensitive about it....
Thanks Charles, Autoguy and plewlandsbob(I guess thats a British name!)--This is quite confusing-I have a set of Chinese offset double end box wrenchs from about 30 years ago that say "BSW" and an old set of Koken sockets that say "BS". These were bought long ago to work on an old MG. Are they "Whitworth" for older Brit motorcycle? And yes, it was the Gedore set I was looking at. I guess that's not quite King **** quality. By the way, if you Google King **** tools you get some unexpected answers!
The Rolls-Royce reciprocating aircraft engines all use Whitworth fasteners.
I thought that AF referred to "American Fine" threads, before SAE became the preferred term, but that would have nothing to do with the head size.
In the U.K. A/F generally means “Across Flats”, as others have correctly stated. This is to differentiate a a British 1/4” wrench that refers to a 1/4” bolt size, from an American 1/4” wrench that refers to the size across the flats of the nut.
American threads were known in America as National Coarse or National Fine, but in the U.K. we had our own National standards so knew these as American Coarse or American Fine.
A/F therefore means “across flats” in respect of wrenches, but “American Fine” in respect of say a thread tap. Both are British terms.
My Grandfather, who worked on British trucks before the war, and American ones during and after, always (correctly) referred to American bolt head sizes as “SAE”.
After WWII, the UK and US agreed on thread standards and the result was called Unified. There was UNC, Unified National Coarse, and UNF, Unified National Fine. The fine series was originally called SAE because it was a standard of the Society of Automotive Engineers. UNF fasteners have smaller hex sizes than UNC for a given diameter, similar to BSW-BSF.
