Anyone only using ratcheting screwdrivers?
mopar66
RI
As the title says is anyone only using ratcheting screwdrivers? I recently got a couple of Snap On and Williams ratcheting screwdrivers and find myself using my regular screwdrivers less and less. I don't really expect them to replace all of my screwdrivers. I have about 60+ screwdrivers. I have a mix of Craftsman Pro, Craftsman, Snap On, Klein, Wiha etc. I don't turn wrenches for a living but I am working on cars or other projects 4 or 5 days a week in my home garage. Here is a pic of the Snap On when I 1st got it and the Williams.
rlitman
Long Island
I use them more than I use their fixed blade friends. There are times when a hex bit just doesn't fit right, or I need something really long...
zkling
No, standard drivers are a necessity. I'm cautious how much torque I put on the ratcheting drivers.
jgorm
San Diego
I hate ratcheting screwdrivers. Doesn't save me any time and drives me nuts when they are on the wrong direction.
Zrexxer
Pflugerville, TX
I've got a three or four ratcheting drivers, and I can't remember ever using one. I always reach for a conventional screwdriver.
n8n
Curtis Bay, MD
I use 'em for space savings... sometimes you need a regular one though, usually a #2 Phillips for a screw recessed in a hole. Not often on automotive apps but around the house.
Sent from my XT897 using Tapatalk
mopar66
RI
The strange thing is I have a black hard handle Snap On ratcheting screwdriver that I have had for more than 20 years and never used it much. Then I got these soft grip ones and seem to be using them a lot.
Uncle_Charlie
Rogers, AR
I have one of the cheapies from Lowes or Home Depot that carries multiple bits in the handle. For a long time, I've carried it in a motorcycle tool kit for emergency type situations- more for the multiple bit aspect of it than the ratcheting function. Fortunately I've never needed it in an emergency situation. But if I'm at home, I'll use a fixed handle over the ratcheting version every time.
Vegaman_Dan
Pacific, WA
Can't use them as a pry / lever tool, nor can you tap them on the end with a hammer without risking damage to the mechanism.
Nope. No need for them in my garage.
koondog
Pennsylvania
I think they have their uses. I find I use mine quite often in the garage. Works very well for me especially on interior jobs. It is magnetic so that may be why it seems so useful to me. But it isn't a replacement for all the other drivers.
RVDan
North America
I use mine constantly. I only use a conventional when the screw is in a recessed hole that the multi screwdriver won't fit into. I don't carry the whole kit with me, just the basics in the handle, and I do get annoyed sometimes having to dump all the bits out into my hand to get the correct one but it beats the uncomfortable handle of a Picquic.
wagzilla
Arizona
When I throw a bag together I always put the ratcheting screwdriver in the bag it has all the bites I need. I also have a 4 to one screw driver it was really cool 15 years ago LOL
James
quattroJoe
FL
Most of the time I use standard drivers, I find that the bit holder on the ratcheting deals often make it difficult to get into tight spaces. Mainly only use the ratcheting driver if I'm going to be sitting disassembling something with several of the same fasteners. They're great for bench work.
Onefastgsx
Indiana
My gearwrench set with ratcheting handle and T handle is typically my go-to set for most cases. It has alot of bits and 1/4 drive sockets as well. But my regular screwdrivers definitely have their place, and are still often used.
ihateminimumwage
Besides my impact driver, I used the hell out of my ratcheting drivers (Snap-On hard handle and Williams T-handle) my last couple of shop jobs and for automotive side work. Only pulled out the regular drivers for scraping or prying anymore.
Current place of employment; I mostly work out of my field service bags whether out on site or in the shop. I learned fixed handle versions are needed, as most people seem to think the area on their property with the deepest mud (usually under a drip line) is the best place to install their backup generator. Bits and 2"+ deep mud (or 4"+ deep snow) don't mix, and I'm not going to be held up on a job losing one stupid bit. Fixed blade screwdrivers, Torx, and nut drivers it is now.
nicksnothereman
In the Mojave
I always end up stripping bits when using a ratcheting screwdriver (but not a bit socket on ratchet setup oddly) so I try to avoid them at this point. Depends on what you're doing/how long the screws are to be honest.
Boiler
Indiana
You're using them wrong, using the wrong brand, or both.
I have a few snap on ratcheting drivers and the beauty is how little drag they have and the round, knurled shaft. I spin my shafts while applying light pressure on the handle to quickly run in or out a machine screw. Then torque them. It's the spin that saves time and effort. I can usually apply the pressure and spin the shaft with the same hand.
Some of the guys at work listened to my preaching but are cheap and bought kobalt or other brands. Tons more resistance, difficult to spin shafts, defeats the purpose. I agree, THOSE **** and don't save time.
Jarhead0408
Who knows?
Gotta say though. I've got a Kobalt ratcheting 1/4" bit driver that is the bee's knee's when it comes to spinning out screws and bolts during HVAC repairs. Especially with the super logn extensions that came with my kit.
Ridge Runner
East Tennessee
My ratcheting screwdriver is my go-to driver. It drove me crazy having to check it every time to see which direction it was set on, but I took a sharpie and marked I and O (on and off) at the detents. Now, using it is a snap. I've never had an issue with putting too much torque on it. The only time it doesn't work well for me is when the shank is too wide to fit into a screw hole.
Mine is the hard-handled Craftsman that Mac also sells/sold.
shampoop
SW Washington
I have one. I use it every once and a while and try to find it a purpose, but realize that unless you can't have a cordless drill around, there's not much use for one. A cordless drill for doing 90+% of the long screws and a standard non ratcheting screwdriver for the last bit is the most effective and preferable. Fastest, least repetitive strain, still have full power/grip with the standard driver.
L.Cheapo
I bought my SnapOn ratcheting screwdriver in 1996. My standard screwdrivers have dust on them. Literally. Cant remember the last time I reached for one other than my SSDMR4B.
vincentshumai
Dont own any ratcheting screwdrivers yet but the Williams and the Wera one is in my amazon wishlist. Just trying to decide which one to get between the two
rlitman
Long Island
Yep. you understand!
As for Kobalt, they did sell a ratcheting screwdriver that was the equal to the Gearwrench. Still not SnapOn quality, but a decent second. They also sell some ****.
Dave455
Sussex, England
I own some ratcheting drivers, and use 'em a lot, but they don't replace a conventional driver!
Like any ratchet, I wouldn't like to apply a lot of torque, so it's always a conventional driver I use for loosening a tight screw. Likewise if I've got really big or really small screws to deal with!
As soon as I've got any volume of screws to tackle I go for the ratchet! Love the Snap On T handle style - good tools and really well thought out! The hard handle stubby is nice too!
ChrisPace
When ever there is a post that poses the question "What is the best tool purchase you have ever made" or something similar the Snap On ratcheting screwdriver is always top runner. That speaks volumes I would say. They don't replace every screwdriver everytime but they are probably the most reached for tool if a guy owns one.
T45
The assembly/dissaembly of bits itself is a hassle. I have a good one and like it for the purpsoses you outline here, but that is not the only purpose of a driver. Alot of use cases don't involve a complete threading of a fastener, like spot checks for loose fasteners, and for these applications, and for adjustments using flat heads, etc...the speed and precision of a standard driver wins the day.
So I say horses for courses with this...neither is a perfect substitue for the other.
Todd.Brock
Cincinnati
I use my ratcheting screwdriver for everything. Only thing I use a smaller flathead is for switch plates and outlet covers. I like the storage in the head of the driver and the fact you can choose a locked position if you don't want it to ratchet. I have six of them for some reason.
cheechi
Triad, NC
This is the right answer. I feel like a toolbox is incomplete without it if what you do involves hand tools at all. But it isn't a replacement for standard drivers.
By that logic turning a standard driver with a hex bolster you sometimes need a rat wrench and sometimes a standard wrench.
The same way you don't always use a power driver. You need different tools for different solutions. For instance, when I do work on my interior car, I can remove anything with the impact driver but I put it all back together with a standard or rat driver so I don't destroy all the old plastic.
