Hey all,
I'm getting ready to do the ceiling and walls in the shop on my pole barn and had a couple of questions. I'm putting up steel dura-panels from Menards for a couple of reasons...cost, truss spacing, etc. I did a search, but got so many results it wasn't helpful, so I apologize if this has been covered before.
What trim combination do most folks use where the ceiling panels meet the wall panels? J trim on one, both, or some other combination?
I'm also undecided on what trim, if any, to put on the bottom of the wall panels. The panels will meet the foundation on three of the walls, and one will go all the way to the slab. I'll add pictures below to make it more clear what I'm looking at. BTW, I will add a vapor barrier to the ceiling in case anybody is wondering
Lastly, on the stick framed partition wall (2x4 16" OC) I need to add strapping, but would rather not use 2x4 purlins like I have to use between the posts on the other walls. I've seen some folks use metal strapping that looks to be 3-4" wide, and fairly thin, but have no idea where to get something like that....any ideas?
These give a pretty good idea of the layout and you can see I started on the side insulation and purlins:
