Monte406SS
Well, the garage is almost done but I have not been around to see the progress. Electrician installed 3 of the 9 T8 fixtures we had previously discussed. I am now looking at adding the remaining 6 fixtures, 3 on each side of the flat portion of the ceiling. At this point all the lights will need to be controlled by the same switch, I am ok with that. What would be the best way to connect each of the outside fixtures to the center fixtures which are already wired (the green line in the attached picture)? I was thinking just a short run of conduit between each one. Flexible conduit would be the easiest due to the angle point of the ceiling.
It *****, everything else came out great, need to snap some pictures this weekend. Garage doors and openers are being installed Friday.
