Power Strip With Decent Mounting Holes???
Richard D
Texas City, between Houston and Galveston
I hate the little slotted holes on the back of almost all common power strips. I have a few expensive strips with steel housings and holes you can put a screw through, but they are $30-$40. Looking for a cheaper alternative.
boiler7904
NW IN
+1
It's even cheaper if you have a decent 12 ga cord with male plug that has been cut / nicked and needs to be replaced anyway.
I mounted a 4x4 box with 2 20 amp duplex receptacles fed by almost 25' of 12 ga cord to the side of my miter saw cart for the saw, vacuum, battery charger and other tools so there is only one cord going across the floor when I have a project going on.
Did the same on my car detailing cart for lights, polisher, etc.
bri_man57
Windsor Colorado
Harbor freight has a 12 plug power strip for 25 (or 20 with a 20% coupon), I have it mounted at my work bench and like it. Has 2 holes on each end for screws.
doan
Frisco, TX
Slightly redneck....
They usually have screws that go in from the back that hold them together. Take out 2 of the screws and drill through, then mount with screws from the front
knobby
down by the river under a Jeep
+1
This
Put it together with some spec/commercial grade receptacles and it will be worlds better than those plastic POS
jgorm
San Diego
Haha, mine is WAY more redneck than that. I take 2 3" wood screws and cross them on the top, then 2 on the bottom to pin it to the wall. Locks it in pretty well for 20 seconds worth of effort, and works on any power strip.
2oolhound
BC Canada
I use the 6' rack mount strips. To anchor them down I bent some heavy gage tin strips the right contour to fit the profile and with screw holes on side flaps. Works great You may have to use heavy wire on those little power strips as there is very little room between the plugs.
sselander
CT
Look for the Tripp Lite metal ones with mounting flanges or "ears" instead of the keyhole slot.
lowbucktruck
Foothills, Northern California
Yeah, definitely avoid those cheapie power strips. It all depends on your use, what you are gonna plug into it. For light-duty use I installed a Wiremold power outlet strip on my workbench, it has a metal case and mounting stuff (plus a built-in circuit breaker of decent quality).
http://www.lowes.com/pd_223771-170-...&pl=1&currentURL=?Ntt=power+strips&facetInfo=
Even though I got the Wiremold strip for light-duty use, I use it to power my bench grinder. For heavy use (power tools) I use my cord reels which are ceiling-mounted and on their own circuit.
I agree with knobby and boiler, for the best outlet strip... build your own. I have hacked together a couple out of electrical left-overs from other projects.
