Mercury Vapor bulb question
phoenix5x
Hey all,
Just purchased a new house and it happens to have a very nice out building on the property. Currently it has mercury vapor bulbs which produce plenty of light for the 50 x 100 area. My question being, are there more efficient bulbs than the mercury vapor that produce similar lighting if not better? Such as high pressure sodium or LEDs?
Syberia
Perris, CA
I had one of those on a post above my driveway. Was a 175 watt bulb, but probably on the verge of death because it was VERY dim. I think replacement bulbs are banned from sale in the US by efficiency regulations.
I actually just replaced the MV bulb with a "300 watt equivalent" CFL bulb from Home Depot. Uses 68 watts instead of 175, and produces much brighter light than the old MV bulb was giving me (and it's more white, as opposed to the bluish light I had before which I did not like). The process requires some re-wiring (bypassing the ballast in the MV fixture) and the purchase of a mogul base to regular screw base adapter, but I am very happy with the results.
Cost to do this was about $15 for the bulb and $3 for the adapter.
Syberia
Perris, CA
If it's indoors, the other option would be to take down the MV lights and put up fluorescent tubes. That seems to be the norm for shop lighting.
P
phoenix5x
Yeah it is indoors but I hate replace all the fixtures at the moment maybe a little down the road got enough to do getting moved into the house..lol
Elginz
Oconto, WI
Put in the big (probably 68 watts) CFL for my uncle. It is a yard light outside in WI, he loves it, still, that was 3-4 years ago.
P
phoenix5x
I think I mat experiment with the 68 w cfl on one of the lights and see how the output looks according to the output the lumens are about half the merc vapor ligts so I will need to compare...appreciate the input guys...keep em coming I am still in the planning phase here
P
phoenix5x
No I think HPS is definitely out The cfl or led is probably the option just looking for the better option for my application..
P
phoenix5x
Haha that's funny..also didn't know there was a Low pressure sodium light
rlitman
Long Island
High pressure or low pressure sodium? There is a difference.
There is, but LPS is really not that used.
LPS is severely yellow, and is completely lacking in blue or green. The color rendition is ghastly (though I used to use a few in a photo darkroom, and there it was pretty nice).
HPS is the orange glow we're used to from street lights. Totally inappropriate for indoor lighting, except perhaps to provide enough ambient light for security purposes overnight.
Neither would be useful indoors.
P
phoenix5x
I believe they are 175 watt believe the one replacement package I have says they are 7700 lumens...the cfl and LEDs that I find are like 3800 lumens trying g to save the wattage with similar lighting efficiency
knobby
down by the river under a Jeep
A direct swap for a mh175/u with a mogul base would give more light with the same hydro usage
P
phoenix5x
Well I decided to try and swap out one of the 400 watt fixtures for a 6 bulb t8 fixture...it's an older fixture but seems to work well...I have a question though...this string of fixtures had 4 x 400 w fixtures wired together I dropped one out and put in the flourescent fixture..now when I power it up one of the other 400w fixtures makes a higher pitch wine as opposed to the normal hum when the power is on...could that be because of the different type of ballast used causing some type of interference? Do you think it is causing a problem that might be dangerous or damaging to the lights in the series
toplessHO
central florida
they make CFLs that fit mogul base
Last time I checked they were around $10 at the box stores
