Work bench back splash
coljar
Belpre, Ohio
I need some fresh ideas. I'm installing used steel laboratory cabinets as work benches along the wall in the shop area of my garage. The back splash will be about 2 ft. tall and run the length of the bench which is about 16 ft. with a built in sink on one end. Above the back splash will be commercial white slat wall with aluminum ribs. I don't want to use peg board like I have in the basement shop. I've thought this thing to death and would like to see if there's something different that I haven't thought of. Keep in mind, I want something around the sink area that's easy to wipe down. The dirty shop sink is in the building next door where the dirty work gets done.
chrispyny
albany, ny
I am in the middle of refreshing my garage. Gladiator cabinets and racking, paint, new outlets and switches and plates, racedeck in the spring.
After having put up the cabinets tonite, next is the backsplash for the 8' bench and i'm thinking aluminum diamond plate. 8' long by prolly 24" tall. Next is to call metal place monday to see how much that might cost.
I need to look into NEC for outlets thru metal backsplash also.
Modern Jess
Bay Area, California
What's your budget? Restaurants often use a kind of quilted stainless steel panel for backsplashes on work areas. It looks really nice, but don't know how much it runs.
Duker
Livingston, TX
I am thinking about using something like the attached stainless tile or a sheet of stainless steel around my sink. I will have an aluminum U channel on the bottom of the slatwall to finish off the look. If I use stainless sheet I will just screw through the slatwall into the studs and the sheet and cover it with the slatwall
C
coljar
Belpre, Ohio
That would look nice. A while back I was in a Walmart restroom and they had this really nice basket weave looking stainless steel between the stalls and on the wall. I wonder how much a couple of 4 x 8 sheet of it would cost?
Modern Jess
bullnerd
Jersey
More texture = more dirt holding ability. Formica...cheap, easy....you'll be dead before it wears out.
rburke65
Canfield, Ohio
The aluminum diamond plate in a 4x8' sheet, then shear it length wise would I've you your 16' 24" high. Dia.plate is sort of over used any more, but.......
metalmagpie
Seattle
If your bench is anything like mine, after a few months you wouldn't even notice a backsplash. I have steel drawer cabinets all along the back of my benches. They extend up 18" or so. I put things on top of them that are too tall to fit into the drawers below the bench top, let alone the smaller drawers up on the bench top.
metalmagpie
Ohio Auto
Aluminum diamond plate...can get them in 4 x 8 sheets...I find them on craigslist around here. Light and would be easy to glue onto any wall I would think.
