The Irwin Hanson also comes in adj. dies and cost less.
On a side note PRO CUT imports are cheaper on some sizes.
Richard
TR TOOL SUPPLY
PRO CUT makes almost every kind of cutter ,taps dies,end mills,screw machine drills,etc.I sell them to some of our customers.They seem to be a good brand for an import,it's comes down to cost ie:1/2" cobalt HD high speed 135 degree split point drill,flute 2 1/4,3 3/4 length-MORSE brand$15.70-PRO CUT $6.00.I like and sell US made tools,just want to give another option!
Richard
TR TOOL SUPPLY
I've got the 76 piece Irwin / Hansen set, no. 26376 which I got on a great Amazon deal for $87, it's currently listed for around $130 on Amazon. Still a pretty good deal, in my opinion. It is carbon steel and is US made. I've been pretty happy with it so far.
The Irwin HSS sets run in the $700 range.
Would I be better off getting a HSS set?
YES
Carbon steel taps **** the big one
Any recomendations on a good set Elroy? I only really need metric.
You will be far better off with high quality high speed steel taps and dies like Greenfield, OSG, Morse etc.
Good taps are an a smart investment, cheap taps are throw aways and worse can cost a lot more in time and moneyto burn out when they break.
Steve
good call...
would an irwin set be good enough for situations like if a tie rod end threads were screwed up? or a similar automotive application? or would you (anyone) recommend getting HSS? the HSS sets are extremely expensive
First thing I look for in a tap is , is it offer in a blow molded case if so I run away and will not put my money on it. Greenfield's are my favorites and always get adjustable dies , as long as your taps do not clang around you are fine.
If a tap is HSS, is it safe to assume it will be marked that way? And if its not marked HSS, it's carbon steel? Thanks in advance for info and man I love this site!!!
