I’m installing a flush mount BendPak SP-7X. I’ve looked at the manual and the other posts on the forum but I still have a few questions:
(1) In looking at the diagram below I’m confused as to what the cross hatched section represents. I’m assuming that the center of the hole is 2 5/8” from the vertical concrete and that the cross hatch section doesn’t denote anything.
(2)As drawn, there will only be 1 5/8” of concrete above the 2” access pipe which is much less than I’d like. I’m not sure how tight the hydraulic and air connections are. Can the pipe be moved lower?
(3) Anything else that I need to think about?
