I am in the process of building my shop. 40x40x10 pole barn
This is my first pole barn.
Poles are 1" out of square somehow. I figured this can be worked out so no big deal.
I hired some cheap labor to help set the trusses and put on the roof metal. First mistake I made I think. Couple of bent metal panels. Not real bad and barely noticeable.
I left the purlins run wild until I squared the metal roof on the side facing the house and then cut the purlins back. Side facing the house is perfectly square. Soffit measurement is consistent on both the gable and eave side.
This is the side that is done. I am now working on the other side. I used a bucket truck to set the face of this truss as perfect as I possible could get it. It may be 1/2" my best figuring. The trusses have a lot of sway until you get them attached to the purlins.
The measurement from the back side of the 6x6 to the front of the fascia is 24".
2nd mistake I made is that I did not start the metal off on the other side. I let the help do it.
I am now starting to box in for the soffit on the other side. This measurement is 27".
I went to the back side and it is the same 3" off the other way which means the left side of the metal is out of square 3" but you can not see it on the roof. It looks square to the eye.
IF I try to move the metal there is no way I think the screw holes will line up once shifted 3". BUT the right side gable end soffit measurement is consistent but the left will be 3" wider at the boxed eave from the ridge.
I have not done any type construction myself in 10 yrs but I did vinyl siding years ago but never dealt with 3" longer soffit before.
Will this be noticeable over a 24' span??
Sorry for the long posts but I need to get to work and really dont know which way to go now
If you look at the OSB ceiling panels inside, you can tell something is a bit odd. Other than that, looks normal.
