Modifications to the HF 4 and 5 drawer service carts - what changes have you made?
twinturbogarage
I just finished this entire thread. I would just like to say thank you to everyone for the great posts. I will be picking up a 5 drawer red cart in March during the parking lot sale :D
Tucker99
Elkton, Maryland
Do all the HF have parking lot sales in March? Is this usually damaged merchandise? Got my $164.99 coupon and just waiting for it to warm up a bit in my garage to put the thing together. A mod I will be doing that was only mentioned once early on is to eliminate the drawer latch mechanism thus avoiding having to open the drawers on the right. Guy earlier said he was just drilling out the rivets on the latch. I'm doing that and installing rare earth magnets on the back of the drawers. I did this with a box in my basement and it works great. BUT that box doesn't move. Going to remove the latch on the bottom drawer, and fill it to max weight capacity and roll the cart around to see if the magnet holds the drawer closed.
Still undecided about the top. Guys with the rubber matting; does it still stay in place with glue, etc? Looking for a heavy vinyl material with a self adhesive backing. Don't see using it as a work bench but it will become a catchall just like every other horizontal surface in my house.
Mcjohn925
Concord, CA
The latch mechanism you're referring to with the rivets has to do with the lid. Once you remove those you will be able to open and close the drawers whether the lid is open or closed. I'm keeping the drawer latches because they're not that much of a PITA for home use. Can't help with the top cover. I plan on using some mylar from work to protect mine. It's similar to 3m clear car bra.
Sent from my HTC6500LVW using Tapatalk
twinturbogarage
I'm not sure, I believe so though. You could call your local Harbor Freight. I will be doing the same on my cart most likely, disabling the locking mechanism when the lid closes. I don't think its mostly damaged stuff either. I called my local HF to see about the cart, and they said nothing about only damaged stuff. You have a coupon for 164.99? Would you mine giving me the code please? The one at the parking lot sale will be 169.99. Thanks
PelicanPines
... snip ... Guys with the rubber matting; does it still stay in place with glue, etc? Looking for a heavy vinyl material with a self adhesive backing. Don't see using it as a work bench but it will become a catchall just like every other horizontal surface in my house.
I used double sided molding tape on the mat on my cart... been months of use... not one issue with the mat. I use the top as a table for other portable tool boxes.
PelicanPines
I didn't bother with the lot sale... paid $185, got my pick of the inventory. $16 bucks less did not justify driving there and possibly miss out. HF is a 30 min ride each way.... time, gas my sanity are worth a lot more than $16.
twinturbogarage
Hahah, lucky for me I live about 15 min away, and there's really not that many people early in the morning. Also I was happy to find they do rain checks, which they should in my opinion. But I hear what your saying, and if this was something other than tools, I wouldn't care. What model is your cart though? Is #61427 the latest? Thanks
twinturbogarage
Also, if anyone has a a coupon for the 5 drawer, please share it. I just called HF and rain checks got brought up, and they said NO they do not do rain checks on parking lot sales, even though YESTERDAY i called and they said they did. Does it change on a daily basis lol?
PelicanPines
Don't have the number handy but its the one with 4 swivel casters (what I wanted). I kinda modified mine a bit... I think my stuff is in this thread around page 52ish +++. Don't forget to lube the wheels, and drawer slides... the lube it ships with dried out on mine.
deafcon
New to GJ here, but I've been reading for a couple of weeks.
Has anyone replaced the casters with the 10 inch pneumatic swivel casters that HF sells? I'm planning to do just that, so I thought I'd ask if anyone has already taken the leap.
twinturbogarage
Yeah you had really good ideas, I really like how you cut the bottom shelf lip out. Also, good job on your cart. What kind of lube did you use, thin bearing grease? If you have the time, do have any pictures of your cart now after a few months? Thanks
twinturbogarage
I don't believe I saw anyone put the pneumatic casters on. Someone mentioned it, but I've never seen it. I personally would put the 8 inch ones on, and would make sure the bolt holes line up properly. If I were to go that route, I would beef up the metal where the casters bolt on.
Tucker99
Elkton, Maryland
I'm sorry the coupon I have IS for $169.99. Yea I get the mode with the lift lock mechanisim. What I'm referring to is the drawer latches. I believe each drawer has a latch on the right that you pull to release the drawer. Pretty fail safe device so the cart can be rolled around without the drawers opening.
Mcjohn925
Concord, CA
There should be a valid coupon for 164.99 in the HF coupon thread. http://www.hfqpdb.com/coupons/3_30in_5_Drawer_Tool_Cart_1423758112.3249.JPG
Yes, 3 latches on the right and 2 on the left.
twinturbogarage
Oh yeah I know what you mean. I thought I was really gonna hate the drawer latch, but after seeing them a couple times I've grown to like them
twinturbogarage
djdaredevil
GH Michigan
I used the 8in on mine and loved it for in grass or rough surfaces.
I did have to take them off before I got pics though because I couldnt
find ones that would hold air even with slime in them.
deafcon
That's encouraging and disheartening at the same time. Were the 8in a direct bolt on?
twinturbogarage
Well, I picked up the 5 drawer cart today. I took it out and assembled, and the holes for middle frame did not line up at all, and the whole drawer assembly was totally non square and the drawers bowed out in the middle. This also causes the drawers to be difficult to close. I'm unsure as to what I should do after spending 2 hours putting it together. And yes this really bothers me that it's not square and bowed.
MadMike842
Did you leave all the bolts loose til the end? I had issues with mine when I was tightening all the bolts as I went. I loosened everything up and it went together much easier and I was able to square/level everything up.
LG63
Sounds like shipping damage or defect. Take it back, it will go together much quicker the second time around.
twinturbogarage
Yep, I even watched multiple videos and read the manual. I put everything together hand tight and then adequately tighten them. I noticed the bowed and non squareness when I took it out of the box, but I didn't want to believe it and thought once i tightened everything up it would fix it. Though to no avail. Not sure what I should do. Thing weighs 136 pounds and is a hassle to take it back. I wonder if customer support would send me one?
twinturbogarage
A couple of the legs upside down?
Nope, put the long side up, according to the directions. Unless there wrong. But even so the drawer assembly itself is damaged. I guess I must be the unlucky percent who get a damaged one. I looked it up and it seems theres barely any report of damaged ones that I could find.
PelicanPines
hand tight might have been too tight. Literally kept em looooose till the end.
madcrisis
I put a set of 8in pneumatic casters on my 4 drawer (NON-HF) for rolling over grass and such. I usually roll my cart around to the front of the house to wok on stuff. I'll post a picture soon. Mine were not a direct bolt match but that was ok since it was top heavy I had to push the swivels out a bit for more stability. Used a peice of angle to stiffen it up. Looks pretty cool in my opinion and has been working great all year.
Not sure on the brand of the casters as someone gave them to me but they work great going over grass and stones.
madcrisis1
deafcon
Those casters look crazy on such a small cart, but I bet they work awesome. I work in a lot of gravel/dirt/muddy yards, so I'm thinking the pneumatic casters will really do the trick for me.
I hope to get my cart project started within a week or two. I read this entire thread, and have a number of mods from it planned. I think I have an old UPS that I'm planning to mount in order to give me the ability to charge my phone/tablet/drills when I'm out on a customer's back forty. The only problem I'm anticipating is needing to clear the whole thing out if I don't have a forklift available to load/unload it.
twinturbogarage
Ok, sounds good. I'm going to return the item tomorrow, and will make sure to put everything together leaving spacing in the nut and bolt. I don't know why, but I feel like HF will give me grief for returning it. Do you think they will take it back assembled? The funny thing is I actually saw someone bringing one in as I was walking out with mine.
skulldrinker
Bolingbrook, IL
I would watch out with going to high with the center of gravity. You could be creating a tipping accident. The 5 drawer has a lower center of gravity than the 4 drawer. The jack looks like it helps a little.
My 4 drawer tipped forward on me and the lid was open so all 4 drawers opened on the way down which made it impossible for me to hold it up and it took a gash out of my hand in the process.
madcrisis
Yeah im very aware of that. Thats why i extended the swivels out a couple inches to increase stability(and to allow them to swivel). I have some uneven patches on the way to the front of my house and it does fine on them. My top box isnt loaded to the top like most of you guys have your tool carts. It just has the basics and if I need anything else I just walk back to the garage. (its not that far away, just wy easier to have the basics on hand) The steel jack does make a huge difference.Plus I put things like my impact or any other heaby tools I might need down there on the way out of the garage.
madcrisis
Wow, a jack and jack stands? Glad to see its holding up. What brand? You said non-HF
I'm not sure on the brand, but I'll go check when I get out there. Ill let you know.
EDIT: And you should ALWAYS use jack stands to hold the load not the jack. Hopefully I'm preaching to the choir.
Tattoograham
Hi
I joined this forum mainly for this thread,
Over here in England the HF cart comes badged as clarke
so this is the first mod done , kept the struts but just extended them so at rest
the lid is at 90 degs
<a href="http://s376.photobucket.com/user/tattoograham/media/t2_zpsl7o5ixc2.jpg.html" target="_blank"><img src="http://i376.photobucket.com/albums/oo205/tattoograham/t2_zpsl7o5ixc2.jpg" border="0" alt=" photo t2_zpsl7o5ixc2.jpg"/></a>
These pic shows the lid past 90 degs
<a href="http://s376.photobucket.com/user/tattoograham/media/t1_zpsjzysy0pn.jpg.html" target="_blank"><img src="http://i376.photobucket.com/albums/oo205/tattoograham/t1_zpsjzysy0pn.jpg" border="0" alt=" photo t1_zpsjzysy0pn.jpg"/></a>
Done/Doing some more mods pics soon
