Hey guys, I got this Speedaire dryer model number 3Z528 for free today and I'm trying to see if anyone is familiar with these units. The cord was shot so I took off the cover and found a plug inside that bypasses the external cord. After plugging it in, the cooling fan comes on but the compressor does not seem to run.
The system looks quite simple, there is a compressor with a cooling thingy in the center of the in/out air supply line coil. The in/out air supply coil has no drain or anything, it's just copper tubing that makes a coil inside the machine and has spray foam insulation covering it and the cooling thingy that comes from the compressor.
I'm wondering if this could be a simple/cheap repair or if I could use a water bottle cooler like below to make my own dryer? I've taken numerous water coolers apart and they have the same setup inside, minus the copper coil for the air supply. I'm pretty sure they will work but wanted to see if anyone has tried it or could help me diagnose this machine first.
