mshell56118
I sent email still do not see name on list
I sent my invoice request yesterday, but the more I look into this unit the more I am starting to have second thoughts. I am sure others of you have been looking into this unit as I have and maybe you found things I haven't.
The thing that is making me the most nervous is the price of and the seeming lack of consumables for the cut50F. Am I missing something in my searches? All I can find are a couple listings on Ebay. Consumables for the regular (non pilot-arc) cut50 models are plentiful from many different online sources and also very economically priced by comparison. Maybe it would help knowing the actual model of the torch and then searching that way.
The cut50F consumables are a good price when included with this group buy which definitely helps, but how likely is it that I will be able to find more when those run out in a year or two? I am starting to wonder if I would be happier in the long run with the regular cut50 just because there are a lot more of them out there so product support would be more likely to continue long into the future. I can get a new torch handle for the cut50 on Ebay and elsewhere for $20 shipped, or a new handle with leads and hose for $50-60, but I can't find any listings for cut50F parts anywhere. Is there some other designation the cut50f goes by for me to find search results? It seems like the more I search the more I feel like a cut50 or a cut50D would be better for my needs. Does anyone else feel as I do or have any other sources for future parts?
The Cut50F uses completely different consumables from the regular cut50.
I want in but I'm working on gathering funds. When is the cut off date?
With respect to consumables, you need to shop based on the torch being used, not necessarily the plasma cutter model. The various different models of Chinese Cut50 have come with different torches, with and without pilot arc.
The pictures in the first post, plus the pictures and YouTube video in the thread linked in the third post show the torch being used is the SG55/AG60/WSD60 style. In my research, the consumables are identical for the Pilot Arc and non-Pilot Arc version of these torches.
The consumables listed in this thread for PT31 or LG40 are not correct. Below are some pictures showing the difference between the two different torch styles:
SG55/AG60/WSD60 torch and consumables: http://i01.i.aliimg.com/wsphoto/v0/...C-Plasma-Cutter-CUT60-60P-50P-CONSUMABLES.jpg
PT31/LG40 torch and consumables: http://i00.i.aliimg.com/img/pb/921/215/387/387215921_585.jpg
Note the PT31/LG40 style uses a reversible electrode, swirl ring, nozzle, and cup. The SG55/AG60/WSD60 lacks the swirl ring, with only a non-reversible electrode, nozzle and cup.
Here are some links posted previously in this thread for the correct consumables:
http://www.ebay.com/itm/18-Consumab...231?pt=LH_DefaultDomain_0&hash=item19cf110fa7
http://www.ebay.com/itm/WSD-60-WSD-...131003132420&rk=6&rkt=6&sd=400455105425&rt=nc
http://www.ebay.com/itm/SG-55-AG-60...425?pt=LH_DefaultDomain_0&hash=item5d3cfbfb91
Incorrect consumables:
http://www.ebay.com/itm/85pcs-LG-40...278?pt=LH_DefaultDomain_0&hash=item27bf3f9b1e
http://www.ebay.com/itm/235pcs-LG40...035?pt=LH_DefaultDomain_0&hash=item3a7790463b
I hope this helps.
Aquamoose I'm not sure you got my PM? Do you now how much to ship to Honolulu Hi. 96819 ?
#253 - jeremy v - invoice just received, and invoice paid. Thanks Aquamoose and everyone else for all your hard work.![]()
I submitted order via email on 7th, still waiting for an invoice.
Here is two photos of the three prong dryer plug and model number![]()
This plug is one of the cheapest and most robust plugs and has been a standard for most welders .
Sent from my iPad using Tapatalk, hobbiest ,Hobart 140 mig welder, Hobart ac/dc stick, miller 250 sycrowave tig, thermal dynamics plasma, Chicago electric 180 mig ( modified of course) , Powermatic/Everede mill.
This unit should come with a wire that includes a L1, L2, and a green ground. You ignore the neutral terminal if you use a 4 prong plug, not the ground.
