creeper storage
blazsawgras
southern va.
no matter where I store my creeper it seems to be in the way. most of the time I lean it against side of tool box. does anybody have better ideas for creeper storage?
NOMAD
The hooks under by large bench put it flat against the wall.
PFSard
Mesa, AZ
It depends on the setup in your work area and how frequently you use it, but I hang mine from the ceiling on the side of a bracket/rail setup I use for storing lengths of wood, pipes, etc.
BearsFan315
Portsmouth, VA
I put 2 Hooks in the wall and hang mine up when not in use.
works great for me... I also hang it it higher up on the wall so i can store things under it as well.
also how i store my spare dollies, they hide in the corner next to my clamps !!
Tink
Old Bridge,N.J.
My box has to be a few inches away from the wall so the top can be opened fully so I just lean the creeper against the wall behind it.
crewchief888
NW indiana
mine used to hang on the wall in the garage, then i put up a huge grinder storage cabinet where it was hanging..
off the top of my head i cant remember where it's at right now...:headscrat
:beer:
MG11068
Seymour, TN
I hang mine on a hook.
Joe Reed
Cordova TN
All 3 of mine are in the attic because I seldom used them. I usually just throw a large piece of corrugated cardboard on the floor instead...
JRC3
Southwestern OH
I bought a creeper like 6 years ago (Way before I bought a mid-lift)...I think I used it once. LOL
It's in this pic somewhere...
Can you find it? (It's red)
:D
Slonaker
Marion, TX
I have the red plastic one from HF. I have it hanging on the wall from a small shelf bracket. It pokes through the handle hole at the top of the creeper. I screwed a small nut and bolt through the hole at the end of the bracket to make sure it doesn't slide off. It was all stuff that was laying within reach when I decided it should hang from the wall...
Slonaker
Jagmandave
Overland Park, Ks.
Yeah, I've had mine for almost 50 years now, but since I've gotten older and now have a mid rise lift, the only thing I use it for is a sort of dolly, to roll heavy things around the shop.
NUTTSGT
Northern Central Ohio
A regular creeper might be easy to put somewhere but a Bone creeper is harder to find a spot for. I've kept thinking about making a bracket to hold mine and somebody has thought along the same line as me.
In the dead space behind the Hydraulic press.
:beer:
xtremek
St. Johns, Mi
I have a gap between my boxes so that I can access an electrical outlet, so the creeper stands on the floor between them
Kev442
Wi
I use cardboard too. Catches the crud and fluids for easier floor cleanup.
I have had mine for 25 years and I just got done testing it today without even seeing this thread. One front wheel will not swivel easily so it is off to the pole building to be used as a dolly for heavier things.
JRC3
Southwestern OH
Me too and I also use sections of carpet. Carpet is nice to lay and sit on and feels good under foot. I remodel so I often keep good clean carpet for this reason. I love it when I go into a newly purchased home where the old owners put down new carpet to sell it. One full bedroom of carpet lasts me a long time with 2'x3' sections.
Brad54
I bought an eyehook (for wood), screwed it into the end of the creeper by the head cushion, and hung it on a single pegboard hood.
Now I have a mid-chest high shelving unit in the shop, and I hang the creeper off the end of it--I set the lower wheels on the bottom shelf, and wrap a bungee cord around the top to hold it tight to the shelving unit.
-Brad
RonB001
Burlington, NC
I hang mine on the wall. Depending on the type of creeper you have, a different hook will probably be required. My hook is a 1x4 piece of cedar cut at ~30 degree angle.
Regards,
RonB
