gs8212
I'm plannning the wiring of my existing basic homeowner attached garage to add workbench receptacles and overhead general lighting. I've been scouring the electrical subforum and learned a lot. The basic questions about circuit loads etc. drove me to one specific question which is the topic of this thread.
The question is about interpreting the compressor electrical label and using that to determine some of the circuit wiring specs.
Here is the label on an IR compressor; small homeowner model.
[ATTACH]415413._xfImport[/ATTACH]
Based purely on the label information I've done a few calcs as follows to see whether I've understood some of the basics.
2hp motor x 746 watts per = 1,496 watts or the approx 1.5 KW.
115 v x 15 amps = 1,725 watts. I guess they're telling me with this info that a 120 volt 15 amp circut is minimum need.
However, since the needed 1,496 watts calculated above is already about 82% of the watts of a 120 v 15 amp circuit, is the conclusion then that I need a dedicated 15 amp circuit with a single receptacle for this plugin compressor? I'll start a different thread on the question of how many other working circuits and receptacles I should plan for the garage.
Thanks much.
Thanks much.
