I'm not seeing the same sku, but generally people have liked the flooring staplers.
http://www.garagejournal.com/forum/showthread.php?p=441083&highlight=flooring+stapler#post441083
Can anyone comment on this particular flooring stapler/nailer? I need to do a small area in the nursery now, and then do the upstairs of my barn later. Pneumatic model at Lowes is about $400!! This thing is only $99 on sale.
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=99640
Thanks for the reply. I did search this thread for "flooring" and found the couple posts where people say the stapler/nailer is good. But, as someone in this thread mentioned, it would be most valuable to make sure that the specific part number is used in these recommendations, just to be sure. I think I'll try the model I showed. What is the HF policy if a tool like that breaks or works poorly out of the box?
Electrical connectors-Fail
Small 2 gal. General Compressor-Huge FAIL
Vice Grips-Fail
Work Stool-Pass
3/8 to 1/4 reducer for ratchet rounded tip right away-Fail
Any screwdriver sold-Fail
Pittsburgh Wrenches-Fail
Impact Sockets-Pass
20 ton pneumatic bottle jack-Pass
12 ton press-pass with modifications
Pry Bars-Fail and ouch!!
Air tools-Pass
Sandpaper-Fail
Elroy purchased these Mity-Vac from the "Harbor" at a better price than anyone else in town:
They are also an authorized Channel Lock distributor so anyone who makes the blanket statement that all they sell is junk has demonstrated clearly they don't have clue what they're talking about.
Now granted a lot of their stuff is imported and not exactly "top drawer" but like the old adage says: Buyer beware applies.
Can you give specifics on screwdrivers as the blue ones I have, while I hate the color, are as good as any brand.
Can't remember specs on screwdrivers had tips break and work terrible as pry bars so I just threw them away.
thing. They sell five or ten different ones under that label.
I used the Pittsburgh wrenches at my boat (that way I don't care if they become fish food) I found the fit on bolts to be very loose. Can't remember specs on wrenches either
The shorty gearwrench type seen very good and the super long ones have been holding up under some abuse here.
And which prybars? I have the black handle ones, four in a set, way pass, so I'm curious which ones failed for you.
It was the black handle pry bars I had the little one broke on shaft and hurt like hell!! The larger one just bent on me
If you buy tools and expect them to fail before you ever use them thats all you will find them doing is failing....
...Uh...what![]()
He’s saying "if you expect them to fail, they will fail" I presume either because you will try to fail them or just assume they fail rather than expect success.
The original self fulfilling prophesy.
I see it every day on cars;
This car is junk, it's a Ford (fill in the brand you don't like) so everything about it is terrible. Sure, I got 300k on it, but the ashtray never worked right.
The opposite is the 'halo' effect where ‘this car is Great' it's a Ford (fill in the car you love). It's normal to put a new engine in every 20 thousand miles, but look at the color.
With tools some worship Snap-On, and can't see the glaring faults, other hate HF and can't see the good.
We ain't tracking tools here, we're tracking human nature.
3 pc. pry bar set - big time FAIL. The head on smallest one (6 inch) snapped off like a dry twig the first time I used it. Really makes me scared to use the bigger ones. I have had good luck with many HF items but the odds finally caught up with me.
Link to product:
http://www.harborfreight.com/cpi/ctaf/displayitem.taf?Itemnumber=97387
17 Piece Heavy Duty Slide Hammer Kit - Fail -
Split the crows foot in half after the 3rd or 4th hit when trying to yank the hub bearing on our '07 Jeep JK.
Not if it's been mentioned yet:
The post dollies, there are 2 designs (altho ideally there should be 4..) They are of sufficent quality steel that you can machine them to other needed shapes & cheap enough that it doesn't matter if you ****** them up...
With the slide hammer and pry bar, did you try taking them back?
Are there any good tire air pressure gauges good at harbor freight?
Mah bad Im talking about tire inflation/gauge a dual foot air chuck...
