va.grouseman
Yes, I think it is one of the off shore wilton clones. Taskmaster or Mechanics is the one that comes to mind.
Taskmaster.---Page 1,---Post #3
Linking the image:
Chris, take a photo of the inside of the body/rear jaw too, where that nut assembly sits.
Sure looks like it. Is it a quality tool? Worth the time if I can find the rest?
Here's where it sits inside the body. I can't tell if that screw in the bottom is just to hold the swivel plate on, or if it's supposed to go through and hold that nut assembly some how?
I meant to take a photo of that section now that the slide and nut are out of there.![]()
Unless there's a lug which the bolt threaded into which has broken off the rear of that nut housing, where it slopes at the bottom rear, then offhand I can't say how that might have been secured originally.
Alright, so I got it all apart and took a few more pictures. This thing has way more moving parts than I thought it would.
But it looks like there's some threads that are stripped (last picture), unless it's supposed to be like that for some reason? One side of the, not sure what you call it, is threaded fine and the other, not so much.
I suspect that is some sort of quick set nut. My Kalamazoo horizontal bandsaw uses a nut very similar to that. It's drilled offset so one way it wedges the nut into the good threads, the other way allows the nut to fall to the smooth side so the jaw can be slid in or out without turning the handle.
HTH, Jim
This might actually be why the nut mechanism was only threaded on one side and not the other, interesting...
Still doesn't really solve my problem, but I at least i know that's probably not it.
Very nice job and vise !
I've never purchased a chain vise before. I have a shot at this one for 30 but i know nothing about them. Any market for these?
Joe, 30 seems high to me for one that is missing most, if not all of the chain...
Here's what I used to clean up the steel table. Does a nice job of cleaning the metal without grinding into it. Gives it a nice shine also.
Absurdly high, you can get them for less, like new shipped to your door off ebay. Chain vises, while handy have little value in the used market, especially those style. Without a full length chain I wouldn't even fool with it.
What's this guy worth if nothing is broke and jaws close good. Said 100 would do it. Too high, lower or about right. Is it a GJ member or just some guy?
Fretters.....I don't know where that little vise is made, it doesn't say Germany anywhere on it. It does have an R..O on it. R is above the O with 2 dots between. I have had it for over 40 years. I used to use it while building model cars in my younger years when I live in New Zealand.
Can anyone tell me how many sizes Wilton were made in? I currently have them in 2 ½", 3", 4", 5" & 6". Been longing to find an affordable 2" for a while now. I think they also made an 8", but I have never personally seen one that large.
Maybe a complete set would cure this Wilton illness!![]()
I need opinions. I am in the market for a vise. Can anyone tell me if this is a good deal
https://lancaster.craigslist.org/tls/4898191557.html
