Streamlight Strion led HL series here. Perfect flashlight for my use. Small enough to drop in any pocket but blindingly bright if need be. Ask the guy on my shift who flashes everyone with his headlight all the time. Mine has been soaked in hydraulic oil, coolant, brake fluid, and even dropped out of a Boeing 777 and still works. The power button is on the back cap so no searching for it. It does have 3 brightness settings all changed from the same power button (just hold it in until the level you want). The HL has the perfect balance of super brightness and wide beam spread. I work at night by the way so a good flashlight is a must for me. No batteries to change and comes with wall and 12v charging power adapters. I usually put it on the charger before going home, but it has lasted 3 nights without charging with moderate use.
777 was on the ground at the time of course, but that is still up there a good ways.
http://www.streamlight.com/en-us/product/product.html?pid=272
