Modifications to the HF 4 and 5 drawer service carts - what changes have you made?
Tucker99
Elkton, Maryland
There's enough flex in the lid that the epoxy would crack and crumble off in sections. That's a two-part epoxy that cures to a hard surface. You would need something for the top of the lid that can handle flex and shock from dropping things on it.
How about plastic dip??
metalgod3082
Can anyone explain how to remove the drawers to get to the slides? I can't figure it out.
Pull the drawers all the way out and there are little levers inside the track. One side you pull up and the other you push down and then pull the drawer the rest of the way out.
SASORacing
Utah
I drilled out the rivets for the locks on the 5 drawer red cart. Those lock were so annoying, if i want to lock it i shut the top lid real quick.
Tucker99
Elkton, Maryland
Snap On Hinges vs Strut Lift
Gents, Has anyone thought of going to a strut mfgr with our dilemma and request a replacement strut to raise the lid 90 deg?? There are ways of forwarding a pic to them with dimensions and they can probably figure our right away the correct strut and mounting procedure. I'm not smart enough to take a pic and "dimension" it but I see it all the time.
cheechi
Triad, NC
Yes. My Sentra hood was pretty much dry in a few hours. Granted it's a large surface area, a thin coat (comparatively) and a summer night, but by the next morning it was dry and ready to go.
That's why I said estimate.
Buckgnarly
VT
Finally got time to post some pics....I had the Lowes tool cart, kept one side shelf before selling plus scored a Snap On side shelf for 20 bucks at the local used tool place. I had to drill holes to mount and relocate the handle to the front and can holder to the bottom, but I LOVE having the folding shelf space with the cart....also added HF magnetic strips for my wrenches.
twinturbogarage
Very cool. Any plans to lube the drawer slides? I used Super Lube last night and the drawers are practically butter. I also bought mine last week and there was no grease, only a very minute coat of thin oil on the bearings.
Buckgnarly
VT
Hmm...never even thought about it or checked them. Cannot say they felt bad, but now I'll have to try!
PelicanPines
Was one of the first things I did... lubed all slides and took the casters apart to fully clean and lube all parts. Noticed and posted in this thread... some of the as shipped lube from hf dried up. Made a huge difference.
deafcon
Picked up my five drawer and put it together this weekend. I put some magnet strips on the lid, but that's my only mod so far. I've got big plans, but I'm about to go on the road, so it's going to get used as is for now.
twinturbogarage
Post pics if you can would love to see it
djdaredevil
GH Michigan
That's encouraging and disheartening at the same time. Were the 8in a direct bolt on?
Sorry for the late reply but yes the 8in ones at HF are a direct bolt on. This was
on the 5 drawer they would not bolt on to the 4 drawer though you would
have to modify the cart to make that work.
deafcon
As soon as I do something to it different from all the great mods that have already been posted, pics will definitely be posted.
Thanks for the reply. After buying the cart I had pretty much confirmed it, but it's good to know I was right. Hopefully I'll have better luck with the pneumatic casters than you did.
djdaredevil
GH Michigan
You might, maybe I just wasn't using enough slime in the tubes idk.
Tucker99
Elkton, Maryland
Picked mine up Saturday. Forgot the item number but I have 4-swivel casters and they are big. Grease fittings in the swivel as well as the axle. Drawers were tight and I greased up the slides and the grabbers. The drawer latches are screwed on and I removed them and drilled out and removed the locking mechanism. Like everybody says badge comes right off with heat gun and plastic putty knife. HF was out of stock on the side shelf so I'm ordering that on line. Plan on putting a sheet of plywood in the top to begin screwing down socket rails.
metalgod3082
Got my 5 drawer few days ago. Mods I've done are the rubber grommets in the screwdriver holes, swapped out the 2 fixed casters with 5" swivels from HF (blue color), ordered snapon hinges, replaced drawer liners with 3mm yoga mats, disabled the locking mechanism on the back of all the drawers so they can open while the lid is closed.
Also used the HF free coupon for the 18" magnets. Plan on picking a few more of those up. Any tips or tricks on attaching those magnets to the lid? I've heard 3M trim tape only lasts so long before it gives out so thinking of attaching with nuts and bolts. Also what is the best way to drill a hole into the lid without bending the lid or causing the paint to chip? Wanna make a nice clean cut hole.
Buckgnarly
VT
I used a step drill bit with painter tape to prevent chipping. Used 1/4 bolts, way overkill but it fit the holes in the HF magnetic strips.
What size rubber grommets did it take? That's a great idea.
metalgod3082
I got the idea from an earlier post in this thread. HF sells packages of rubber grommets for like 4.99. It had all the sizes I needed for each hole. The largest size was kinda tough to get in but if you keep working at it they will eventually go in. I was short a few of the largest and 2nd largest sizes tho so had to buy 2 sets of the packages. Now I have like 100 leftover grommets.
MadMike842
Guys with the grommets. Do the screwdrivers sit well or do they fall over? Without them mine tip occasionally but I'm curious if it's better or worse.
twinturbogarage
I was just about to say, I absolutely hate having the grommets in. All the screwdrivers either fall over or they don't stand up straight and move like crazy. Without the grommets they are fine, but sometimes the handles aren't wide enough and fall through the holes on some.
JMToolCo
^ this
PelicanPines
Guess it depends on your screwdrivers... I have vintage craftsman and fit much better with the grommets. My SK screwdrivers (laser tip) do what you describe.... kinda fit better without.... but they live in a drawer in one of my towers... when I got the SKs they came with a holder with very small holes...
twinturbogarage
Click on "Go Advanced", slide down and click on "manage attachments", click on one of the white rows in the pop-up that says "no file selected", find an image to upload, click "upload" ... now close the pop-up and your done.
Easy squeezee ... :D
Thanks I was thinking about posting pictures of mine when a few mods were done. I really don't have much but I'll share anyway sometime soon.
