Should I pick up this milling machine?
coma13
I've had my eyes open for a reasonably priced vertical mill for a while, and this one caught my eye. I emailed to see if I could go check it out.
Any experience with these? Things I should look out for? I'm not familiar with Westbury but I learned on a manual Bridgeport so familiarity would be nice for a garage tool.
http://sfbay.craigslist.org/nby/tls/4903193992.html
astroracer
Mid_Michigan
Go check it out. If the seller is motivated he should let you fire it up. Check the spindle bearings for growling and any slop. Check the table for backlash in X and Y. If you find a "few" things out of spec you may get a better deal...
Mark
rsanter
visalia ca
Seems a little bit high on price for condition to me but you will never know if you do not go look......so I will say maybe......
Bob
nine4gmc
Dallas
That thing would be $4500 around here, definitely grab it if you didn't miss out by posting it here and waiting for replies...
iajonesy
Iowa
Mill looks good and comes with some nice add-ons that make it a pretty good bargain if it checks out okay.Like 94 said,they bring a lot more than that in my part of the universe,too.I'd be all over it if the spindle,backlash and motor are good.Lot of bang for your buck.
Mike
Bobf
Poway, CA
Go check it out. Check X/Y play, run the table out one side look up under and check the lead screw for wear in the middle(flash light) grab the end of the table and see if it moves front to back when you gently push on it.
Check the spindle for wobble and bearing noise if you can power it up.
If it comes with the tooling in the pix it's a good start.
Any mill is useless without the tooling you need for whatever you intend to make.
C
coma13
I sent him an email before I posted. Hopefully he gets back to me.
-Eric
Caman
MN
I will add, Run your finger inside the spindle where the collet goes and make sure it is smooth and not all rusted or galled from a spun collet. Also check the drawbar for stripped threads.
gearhead1
NC
Look for the things others have mentioned, but IMO, yes it's worth it. You won't find one around NC for that. I paid $800 for my Bridgeport but had to go two states away to get it. It had slop in the table, but still worth it.
sgs236
Fairmont, WV
I'm thinking that Kurt 6" vise might be worth between 150-250 (depending on condition) by itself. Collet set maybe another 50 dollars or so.
C
coma13
Going to check it out after work today. I'm 1st in line but there are other interested parties.
KMScott
The table is the short version, maybe 32" check the low range too. See how it drops into back gear. might want to check out the down feed also, see if it the down feed goes into gear and try the three different feed settings and if the feed reverses too. If from a shop then it is being sold because of something. Well worth $1,300.0 if everything checks out. Good luck.
DocsMachine
A better question might be "why haven't you already gone to pick up this milling machine?" :D
Doc.
C
coma13
It's mine! Put a deposit down on it after checking it out today. Going to pick it up this weekend.
Being sold by an individual who had it in his metal fab shop for the last 25 years and closed his doors a couple years ago. It's covered in grime but feels tight, R8 collets, very quiet as far as bearing noise is concerned, some backlash but no play in the table.
C
coma13
He's digging through his other workbench to see what other tooling he might be able to throw in. I'm pretty excited.
I have a buddy at Hertz who I will be renting a drop deck trailer from this weekend.
ttpete
Dearborn, MI
When you go to bring it home, drop the knee all the way and rotate the head down until it touches the table. It'll be a LOT less top heavy.
bczygan
DETROIT! Arsenal of Scrappers
And support the head as you rotate it.
And lock the table in both directions.
Use a chain and chain binder on the base, but not on the knee.
Ratchet straps from the eye or ram to trailer corners.
Check that handles are secure, or remove them.
When you get home, and it is safely in the garage, stand back and chuckle out loud, realizing how great it is to have your very own mill!
C
coma13
Thanks for the tips fellows. The gentleman I'm buying it from had moved it 4 times in the course of his ownership and we are both on the same page as far as moving methods are concerned
C
coma13
It's a good thing you saved money on the purchase cause you're going to need a lot more for the tooling. What do you plan to use it for?
Don't I know it! Every tool purchased triggers the need for about 10 more. I need a horizontal band saw now, something fierce.
I build custom motorcycles and work on old bikes so it will be used mostly for fabricating parts, repairs, and possibly some engine work.
C
coma13
The move was a success. I did it by myself using a come along/rolling it on pipes and a rented scissor lift equipment trailer. The unload was a bit scary due to a steep exit angle at the edge of my garage, but I was able to roll it into the center on Friday.
I got some steel wheels and heavy duty steel casters from a local recycling yard and I will be building a mobile base for the mill before it gets shoehorned into it's semi final resting place.
I have a manual on order and will be going through the machine and doing a more thorough clean and lube next week but today I am just giving it a wipe down to remove a few decades of shop grime and expose the 58 year old Italian machine underneath.
Strouty
Southern Maine
Nice.
I am interested to see your mobile setup, I have been thinking about making mine mobile, of course I own a forklift, but sometimes access is a pain.
