twinturbogarage
- Joined
- Jan 3, 2015
- Messages
- 51
Hahah good to see your still posting on the thread. I loved reading your posts.
Any tips or tricks on attaching those magnets to the lid? I've heard 3M trim tape only lasts so long before it gives out so thinking of attaching with nuts and bolts. Also what is the best way to drill a hole into the lid without bending the lid or causing the paint to chip? Wanna make a nice clean cut hole.
Got my 5 drawer few days ago. Mods I've done are the rubber grommets in the screwdriver holes, swapped out the 2 fixed casters with 5" swivels from HF (blue color), ordered snapon hinges, replaced drawer liners with 3mm yoga mats, disabled the locking mechanism on the back of all the drawers so they can open while the lid is closed.
Also used the HF free coupon for the 18" magnets. Plan on picking a few more of those up. Any tips or tricks on attaching those magnets to the lid? I've heard 3M trim tape only lasts so long before it gives out so thinking of attaching with nuts and bolts. Also what is the best way to drill a hole into the lid without bending the lid or causing the paint to chip? Wanna make a nice clean cut hole.
Maybe they're out of stock?Still waiting to see if my local Harbor Freight will start carrying the side shelf. Would love to add that to my 5 drawer unit.
Mine sold out fairly quickly.My local HF had about 5 of them as of yesterday...
Do the holes line up?Here's a list of things I've done to it:
Added handle from 44" cabinet
I installed the HF shelf on my 5-drawer. Bought their rubber drawer liner to put down on the top of the shelf with some adhesive spray. My only reservation is that the shelf doesn't take much of a vertical bump before it disengages from its "locked" position. Trying to think of a solution to make it a bit less likely to dump everything. But asking you guys seems easier than thinking for myself.![]()
................. My only reservation is that the shelf doesn't take much of a vertical bump before it disengages from its "locked" position. Trying to think of a solution to make it a bit less likely to dump everything. But asking you guys seems easier than thinking for myself.![]()
Just got my SO hinges put on, best mod so far! Lid near vertical, easier to read my wrench sizes, opens and closes quicker, and will never wear out!
The reflections make it look pretty bad.
Do you have zoomed out pictures of this?
What was your prep work for painting?I will take one later when I put the drawers back in. I painted the silver drawer handles black for kind of a Hazet look.
The Snap-on hinges arrived today also.![]()
A little bit of scuffing, then Sail Blue Rustoleum rattle can.
It could be better and it probably won't be that durable. I will probably have to touch it up a couple of times a year.
I wasn't sure how much work I wanted to put into it. In the end, it is still a cheap Chinese tool cart.
If I had it to do over, I might not have bothered with the paint as it was too time consuming. Snap-on hinges, yes. New lid handle, yes.
Looks like you did casters too... the bolt holes look different... I could be wrong.
Oh yeah, did that also.
It came with two straight, two swivel. I wanted all swivel. Out of all the casters I have here, none were the right bolt pattern. So I just used a quality set of Wagners that were the same wheel diameter.
I also drilled out he rivets for the lock bars and removed them.
[/QUOTE![]()
this would be perfect for me when i have my archery shoots out back. instead of taking my tool box i could use this, would be nice with those wheels being able to roll over the grass.
Cool, mine came with 4 swivels... somehow I think we talked about this already. Can't wait to see your finished product.
Has anyone used 3M's Command product line? Like the hooks with the strip adhesive. I've been thinking about that for that last month. No drilling or anything, and could hook it right on, like wrenches and pliers. I'm gonna do that and get around to posting some pics.
