Laying Concrete
Fin199
North Scotland, Great Britain
Hi, I've got a old shed that i wish to transform, but firstly i need to upgrade the old floor. The floor has been made up of old flagstones placed on bear soil. and over they millions of years it has became uneven and a really health hazard. not to mention the damp created. So i have began work or ripping up the old flags and now need to dig down. My plans are to put down some damp core, then put down 2inches (50mm) of kingspan/celotex insulation and then pour 5inches (125mm) of concrete onto of that. the insulation would have to have holes bored to support the concrete. how does this sound? any suggestions would be much appreciated
Thanks
Findlay
kd3pc
Northern Neck
You will need to dig down further and create a sub base that will support the concrete floor to come.
In most areas, that means 8-10 inches of removed soil/top/sod and then tamped layers of gravel/stone AND then your insulation/vapor barrier. then steel and finally the concrete poured.
Not sure what you are boring the insulation for? It should be as close to one big sheet as possible for maximum effect as a thermal break.
Best of luck.
Chris705
The Finger Lakes of NY
No need for holes in your insulation board, just lay, place & pour it right on top of your EPS or extruded foam board. I believe "damp core" is like a stone dust base? A fine mix that packs well. "Celotex" is not polyisosanurate is it? You don't use that type of insulation below grade.
Notgrownup
Snow Hill NC
Mine is 4-5" with fiber mesh in the mix vapor barrier and 12x12 footers... I don't have much freeze n thaw here...
