1930's siemens schuckert drill
Dajn
Another old tool that I got from my grandpa. It is supposed to be 220 but is was converted to 110. Still works fine, used it today. I suspect it had way more power before the conversion. I wonder if it would be difficult to convert back to 220. Just has an on off switch. I understand why they quit doing that. As I understand, it was made in germany in the 1930's. Pretty cool old drill.
tiggi
USA
That is pretty cool. You'll need to open up the motor and see the connections. Post some pics so we can help you.
Fretters
South Yorkshire, England
Those are a lovely drill, both to look at and use. The on/off switch with those isn't as dangerous as you'd expect, if it snags. As I found out quite early on, it gets toggled off by your knuckles if the drill starts to twist in your grasp. :D
CNGsaves
KS and OK
Where are you located OP ?? Now would be good time to Update GJ Profile with City/State/Country.
From motor plate, looks like it is 50 Hz . . . . thus work only overseas ??
Stuart in MN
Minneapolis
It will have the same power, no matter which voltage it runs on,. It just draws more current at 120vac than it would at 240vac. Also, it will run on 60 Hz, just faster than it would at 50 Hz.
ttpete
Dearborn, MI
It has a universal motor. It'll run on DC also. Frequency doesn't matter because it's not a synchronous motor.
DuroChrome
Oregon
So this is a DC motor with brushes and a rectifier? I don't see any brush access covers, but I'm not too familiar with 1930s drills either.
