Ceezer
Hey, y’all. I have a 2-car attached garage that has been plaguing me for years as it seems I can never get it organized enough to stay organized for any period of time. I also don’t enjoy spending time in it as much as I wish I did, so I try to motivate myself to go out and create a space that I can call home, but then I get overwhelmed by how much work is needed and I don’t know where to start, so I put it off and go find something else to do.
I’d like to have separate (or at least coexisting) space for working on my project car(s), working on wood or other hobby projects and for hanging out, but I don’t know if I have enough room for all. The project car is currently parked in the driveway, but the garage is cluttered with miscellaneous lawn equipment (riding mower, push mower, chainsaw, weed eater, hand tools, etc), gym equipment that is not in use, and bikes and various sporting equipment belonging to myself, my wife and my daughter.
Through reading as much as I could prior to posting, I see the first suggestion is to remove all the lawn equipment from the garage and put it in a shed. I’ve wanted a shed for a while so that stuff would have its own space, but one issue is that I live in a hill. My back yard is approximately a 30 degree incline while my front yard declines at more like 45-50 degrees. There is one spot in the upper back corner of my back yard that I think would be easiest to level off (after I relocate the Magnolia I planted there several years ago) and place a building on. Any recommendations on building type? I’ve heard steel praised over wood due to the fact that the cooling and heating of wood structures can lead to splintering and splitting, but I don’t know if that would be an issue here in SC.
Another issue with the garage is that in the summers, when it’s 97 degrees out and the heat index has it at 110, it feels 3 times that in my garage. I know my doors are contributing to this (they’re the cheap non-insulated single-layer steel doors), but they both have damage and will be replaced in time. I have to wonder if my exterior walls are insulated. I have a closet off my garage that doesn’t have drywall and the 2 walls there that are exterior have no drywall stuffed between the studs, so I don’t know if the ones in the main area of the garage were insulated before finished off. I’m going to try and find somewhere inconspicuous to cut a hole and check. But aside from that, any tips for heating and cooling an existing garage? There are no windows for an AC unit. I saw one garage in the gallery that had a ceiling fan, and I have 2 overhead lights that might good locations for fans. I’ll have to check for clearance between that and the garage door, though. Plus two of the only three outlets in the garage is on the ceiling next to those lights (for garage door openers), so that actually probably eliminates the possibility of putting fans in.
I also have uneven floors. I guess water getting in the garage (because it runs off the back yard and pools up in the driveway right in front of the garage doors, where it’s semi-level) was an issue with a previous owner so he built up the garage floors to keep it out. Instead of raising the entire floor, just the front part of the garage is, and then it ramps down about halfway through… One of my top priorities would be to level this off, possibly throwing a finish on it. What kind of preparation would be needed to the existing floor to lay more cement on top of it, or is that even possible?
It’s also a nuisance that there is only one ground level outlet. I suppose that if I find out there’s no insulation in the walls and I have to tear the drywall down then I can run some more. On the other side of the garage I have an extension cord hanging from the ceiling outlet. I’ve just never seen a ‘finished’ garage with so little thought put into it as this one apparently has…
The cabinets are what I was able to salvage (they were built in, and not done very well either…) from a kitchen makeover. Some of the doors were lost in the mix so I just left them all off as open storage. The base cabinet also has some damage from where I had to cut it up to get it out the door, but I plan to repair that. Do you guys think these look ok, or should I save up for some more appealing cabinets? I could probably put these in the closet, if I needed to.
I know I’m going to have to figure out and do this on my own, but I guess what I’m asking for is advice or suggestions before embarking on this journey
