hancock1701
Hi guys,
I see most metric combination wrench sets from everywhere (HF, Craftsman, etc.) skip the 9mm size. The other day I was bleeding the brakes on a 2009 BMW 328i, took the 10mm to undo the bleeder valve, too big, then tried 8mm, too small. I was like "Damn, I need a 9mm", but I don't have it from my HF set as well as my GearWrench ratcheting set. Most wrench sets under $100 start from 10mm up.
So, how common is 9mm? And what do you guys do when you only need that one size on a car you own, but if bought separately, will not match any of your current sets, hence no where to put it in your included wrench rack or roll pouch?
Edit: By the way, I used an SAE wrench (forgot what size, because I'm not familiar) to get the job done, but I kinda had to force it onto the bleeder valve, the fit was horrible.
