My new compressor
iagsxr
Vinton, Iowa
So got me a new compressor:
6'+ tall, 900lbs, 26cfm@175psi of wholesome goodness:
It's an Eaton. Don't remember anyone really talking about them on here. Built to order, domestic components, 5 year bumper to bumper warranty. Reasonably priced for what they are. The people who I've talked to that have them say they're a good piece.
The only reason I needed a compressor this large is for a blast cabinet. If you've ever blasted with good equipment, I'd rather pay someone to do my blasting than not have enough air. This one's got a continuous run valve so you can just let it eat while you're blasting.
They have a choice of tank colors. The tan's a little yellower than I would have liked, but it'll be ok.
If there's any interest I can let y'all know how it is once it's wired up and plumbed.
C96
Looks bad-***, did you know it’s a Saylor-Beall clone?
Although not a real S-B, I’m sure it will treat you well and 5 year warranty can’t beat that!
Have fun with her!!
Oh, and the paint looks great too! :thumbup:
Ben Buck
S. W. Ohio
WHOA!!
Very, very nice, keep us advised on the set up, piping and ect.
I hope I, We, don't see pvc,pex, or anything of the such, involved in the set up.
stage20
pcola FL
did they over inflate the shipping weight to charge you more or was it free shipping. 900#? id have to question that unless you weighed it. nice piece. ton of air there.
Ameshel
I have the same unit except it's "Panther pink" . Mine is 8 years old and is still purring along. Only maintenance she has needed was oil changes. I plumed a hose barb to the oil drain and ran a hose to a 1/2 gallon collection bottle makes changing the oil a snap with no mess. I am not in the shop right now but they recommend an compressor oil and have been using it since day one with no issues. You will probably find that your compressor will be able to stay ahead of your blast cabinet and will actually cycle off. If you have any questions about your unit let me know and will try and help. Andy
Sent from my iPad using Tapatalk, hobbiest ,Hobart 140 mig welder, Hobart ac/dc stick, miller 250 sycrowave tig, thermal dynamics plasma, Chicago electric 180 mig ( modified of course) , Powermatic/Everede mill.
Zrexxer
Pflugerville, TX
Why are the pump and motor spaced up off the mounting plate? And is the motor sitting on a block of wood painted to match the tank? Sure looks like it when you view the pic full size...
PT Doc
Should be a good unit. Kind of weird that there is all kinds of bent copper around the unit. Be careful with that when working around the unit so you don't bonk it. Keep Us posted on how it works for you.
The thing the motor is sitting on is a motor adjustment plate, my guess. Allows you to change the position of a motor once you have it mounted up.
Zrexxer
Pflugerville, TX
Well, the pump's up on angle iron welded to the deck too. Doesn't make any sense. Every other compressor I've ever seen just has slotted holes in the deck for the motor so you can adjust the belt tension.
8man
Bryan, Texas
Which one is it? i'm looking at a Polar Air and would like to find out more about this unit. What hp is the motor? is it the 4 cylinder pump? How much noise does it make? Thanks for any help.
Robert
tarbellb
Oregon
It seems like they may have changed the motor and pump mounting locations, and the old deck doesnt match up anymore?
Look at the close up photo, there are holes in the deck. Does seem odd.
Nice looking unit though, plenty of CFM.
I
iagsxr
Vinton, Iowa
Robert
It's this one, 7.5hp, V4:
http://www.eatoncompressor.com/catalog/item/504747/9381214.htm
Mine's 3-phase because I have it. They make a single-phase version.
I'll let you know how loud it is when it's operational. I looked at some other brands in operation then compared their published noise data. As long as Eaton's published data is accurate it's going to be about as quiet as a compressor this size gets without silencers and stuff.
CNGsaves
KS and OK
Wow, nice compressor !! :thumbup:
About all you'll "need" now is intercooler, franzinator, aftercooler, & stainless steel airline system !!! :D
/ monster compressor envy
600SL
Connecticut
Looks nice. I would like to know if it really is only 34" wide at the widest point up top.
scw1991
Will Eaton also warranty the foreign motor for 5 years? If so, that's one hell of a warranty.
I like the adjustable tensioner bracket assembly for the motor as well as the simple unloader valve for continuous pump operation.
Cope
Houston, TX
Yes, and adjusting one is a *****. I added a Grainger plate like that one to my Jet bandsaw.
Cope
Houston, TX
I hate to hijack this great thread, but can anyone tell me where I can find a replacement cover for the pressure switch? My compressor is nearly 25 years old, and the cover is getting brittle. It is Square D, the same as the one on the OP's compressor.
2004.5cumminsman
Oregon
It looks like they bent the copper lines over there knee!!! QC is a thing of the past.
Other than that it's a great looking and will offer great performance!
theoldwizard1
SE MI
From looking at the web page, it appears that the motor is raised for the belt tensioner mechanism.
countryroad82
Kentucky
I've had an Eaton for about 3-5 years (time flies I don't know how old the danged thing is lol) it's been great for me for my shop due to paint I g and running a blast cabinet. I need to adjust the valves but other than that it's been great. Anybody know how to do that btw?
samendolaro
I just received a the single phase version of this same compressor last Wednesday. I'm in the process of installing a 3/4" maxline system then I'll move this to its final resting place.
EDIT: Looks like mine has valve problems out of the box , definitely some QC issues. Tech Support had questionable knowledge. I may be returning this.
I
iagsxr
Vinton, Iowa
So I haven't had time to do anything with this, decided today to get it off the pallet and sitting roughly where it's going to go:
Stuck a couple 6' 2x4s under the motor plate:
Blocked in between them so they couldn't slide under the motor plate and so the straps weren't pulling against anything on the compressor:
Notice wooden motor plate^^^
The other side needed spaced out farther to clear the constant run valve and the pump:
Slings:
Pick it up, set in place, safe as a kitten:
I should say it was already sitting almost where it was going to go on the pallet. This is not a carry set up.
Before anyone asks, the forks on my forklift won't go quite wide enough is why I didn't just lift under the 2x4s.
Need to contact the company Monday. I have it in my head they want it 18" from the walls. That's not going to happen, but I better double check just to be sure.
redmondjp
Redmond, WA
It has to do with allowing enough airflow. I wouldn't loose any sleep if you had at least 6" between the belt guard and the wall.
