How to quarter a brake rotor?
GromitInWA
I have a couple of brake rotors that I took off my car and would like to make something like this bookend.
What do you guys recommend for neatly quartering the rotor?
A_Pmech
IL
I would not use a used rotor. Besides the mess aspect, rotors develop hard spots which makes them hard to machine.
A new rotor could easily be cut into quarters with a band saw.
G
GromitInWA
Thanks. Just saw a YouTube video of someone using a plasma cutter to cut one in half, so looks like that's the way to go.
G
GromitInWA
Interesting. Thanks for the advice!
jsaw
Geneva, N.Y.
Cut off wheel in a 9" right angle grinder, or if you can figure out a way to clamp it in an abrasive chop saw
koditten
Midland, Michigan
Band saw is the eaiest and cleanest. I've done it both ways. Band saw runs right thru them. On the side note, trying to clean them up with a grinding wheel does not work very good. Best thing is to get a clean cut with the band saw and not have to spend 2 hours trying to make them nice and neat with a grinder.
mustangmike6996
Detroit MI
It all depends on what you have access to. As long as you have a steady hand you can go with any of the above-mentioned methods.
Personally, I like plasma cutters but if you are free handing it then there is more room for errors. the cutoff wheel (larger the better) is more accurate but will take longer.
tk421
Dayton, OH
i have a brand new cross drilled and slotted rotor from a toyota tundra i can set you up with. i only have one
ADSR
I'm lazy. I would take it to the water jet place and have it done for 20 bucks in 5 min.
zkling
Bandsaw, I've done it before for someone that was making furniture. They cut surprisingly easy for what they are. Touch up the edges on a the belt sander.
As AP Mech mentioned, best to use new parts for industrial art, especially when the component in question is a cheap brake rotor. Otherwise a good long soak in the parts washer is in order.
Showkey
"MEMBER EMERITUS"
Wausau WI
No band saw, no plasma...........sawsall with a quality metal cutting blade clean up with a disk.
Techie1961
Pickering Ontario Canada
Cast iron will dull a bandsaw blade really quick, especially a used rotor, and they aren't cheap to replace. A few hack saw blades are cheap and it won't take much time. Zip wheel on an angle grinder would be my go to tool or like Showkey says, a sawsall. Sawsall blades ain't cheap either though.
