torqueman2002
Feb. 06, 2018 - Because of PhotoBucket's change in 3-rd party hosting, this thread has been edited to post pictures directly. Therefore, the first post has been split and continued begning in post #36, below.
This is a continuation of post #1291 from the "let's see your craftsman block grinders" thread. http://www.garagejournal.com/forum/showthread.php?p=3887111#post3887111
CL ad.
Brought it home for $20.
Close up of tag/label. I make it out to be a 1/4 not 3/4 HP. Looks like 1 61 on lower RH, manufacture date probably.
No date stamp on bottom cover, no capacitor or start-up relay; but 3-wires leading towards windings. Probably it uses a start-up switch to enable/power the start-up winding. {Later pictures reveal the 'white' wire does lead to a start-up winding switch.' A second 'white' wire [not visible] runs from the other side of the switch to the start-up winding.}
I removed the RH grinding stone, performed a visual inspection - no cracks. Performed a 'ring-test' - failed. I broke the wheel apard before disposing of it in the trash. Still no signs of a crack, but it did have a semi-hard arbor bushing. I wonder if that is why it failed the 'ring-test'? It sure as hejj 'rang' when it was hit with the hammer before it broke apart.
LH wire wheel removed. Note: the inner flange was on backwards, and a brass fitting was used as a spacer. Also the wire wheel's crimped flange was loose.
Continued in post #36, below.
Thanks for looking.
Comments and suggestions are encouraged.
CL ad.
Thanks for looking.
