Lowe's Clearance Thread 2015
Status
Not open for further replies.
Engine
Kentucky
I picked up one of these blades from my local Lowes... left one on the shelf as well. $15.05
Glad you could take advantage of it.
I tried to find the 3-pack of blades in my nearby Lowes (the ones I posted above.) The website shows that there are three units still in stock there. I searched, several employees searched, but nobody could locate them. Finally they concluded that it must be a "miscount." Yeah, right. More likely it's "misplaced." Probably later to be "found."
My success rate has been fairly bad with the deeply discounted items on Lowes website. But sometimes they do have some deals, so I guess it's worth checking anyway -- and I'll keep posting them when I notice them.
I also noticed that they have started putting the yellow tags on lots and lots of items throughout the store. You know, the ones that show a small discount. They were doing that a few months ago, then they took them all off and went back to regular price on everything. Like before, it makes it hard to tell the real markdowns from the others.
WilltheEngineer
Central, FL
i picked one up yesterday for 25.91 i think it was. keep your eyes peeled!
easton PA store. last one.
Anyone have a $25 or less price tag pic they could post. I'd be grateful..... My lowes still has it for $50 something. Sometimes it seems as if the workers wait till the item goes really low in area pricing, and the item will go from $5off to ~75% off...
03protege
Louisiana
Liquid wrench penetrating oil was around $1.70 at my store. Down from $4.99 or 5.99
There was also a ton of other lubricants on clearance but that was the best (deal).
NorthNjWK
Northern NJ
alxdgr8
Seattle, WA
That nationwide price is $46.** + free shipping (just set it to any store with 0 in stock) and select parcel shipping. Sadly the 15 of 50 coupon code doesn't appear to work anymore, otherwise that with a filler would take it to $35.
CarsonConcepts
North East, MD
Kobalt 39" Work Bench
#595505
$119 was $199/$159
rice rocket
lol. Is it me, or is the perspective botched on that second photo?
Or maybe it really is a trapezoid.
CarsonConcepts
North East, MD
Haha, checked the non-cropped version that's on my phone, it's certainly off. Picture was taken at a bit of an angle to the box, but not enough to do that.
~ Carson
pablo94sc
Memphis
Posted in hvac as well.. If you need some insulation, Lowe's is clearing out the Johnson Manville insulation to make room for Owens Corning. Looks like 20% off now. Ymmv as it may be a local or regional thing, but wanted to let you know
pablo94sc
Memphis
Not a fan of the Dewalt bits. Bought a set on clearance a year ago to get a bit extension and screw holder. Snapped 3 Philips bits in seconds. Cheap metal.
Delfonik
Warner Robins, GA
$15 off $50 code.
4700RRRRR24682R
Replace "R's" with random numbers. Try different combinations if you can't get it to work. I got it to work for me.
Never seen this coupon, it's usually $10 off $50.
Expires 3/16/15.
JohnKal
New York State
$15 off $50 code.
4700RRRRR24682R
Expires 3/16/15.
Delfonik, thanks a ton for the heads up. Just placed 3 separate orders for the 20% off insulation. the code worked each time, first try. Saved nearly 48%!
Thanks again man..:beer:
pablo94sc
Memphis
Thanks for the coupon code! I ordered some insulation using that code. Took me two times to get a working code, but that's worth $15 in my pocket. Now I have to go pick it up tomorrow and bring the receipt for the insulation I already bought so I can "return" it. LOL
cagullett1
North Texas
What is the deal on insulation? I'm not seeing anything on the website for 20% off insulation.
archirelic
texas
That workbench at the 119 price is a really good deal. I've seen it in store and messed around with it...the steel feels real solid and is a nice gauge. Much nicer than their other workbenches with the pegboard backing & drawer units attached to them. If I could find one at that price, I'd definitely ****** it up.
Anonymoose
Nashville, Tennessee
Picked this up last night. It was $69.99, marked down to $25.99. It was the last one they had, and it had apparently been returned; plugged it in, and it was working fine, so they gave it to me for 20 bucks.
http://www.lowes.com/pd_189342-7999..._clickID=3e25a17a-d503-8828-d208-00005169cba8
IlliniBone
Denver, CO
Thanks for the $15 off! Just bought some lumber and wood screws totaling $52 and it worked perfeclty. Thanks again.
cagullett1
North Texas
It's the Johns Mansville brand insulation.
Are you seeing that marked down on their website? I know the website is supposed to reflect in-store pricing, but when I look at Johns Mansville insulation online, none of it is marked down. If I have to go in store to purchase at 20% off, I guess there is no way to double dip with the $15 off code.
pablo94sc
Memphis
Are you looking at the in-stock or website tab? It could also be a regional thing. See if you get the 20% if you change to zip code 38017.
captain14
$15 off $50 code.
4700RRRRR24682R
Expires 3/16/15.
I tried this code multiple times using the copy and paste from this page and inserting random numbers in place of the RRRRR. No discount.Would there be a set number of discounts per active date and then it stops accepting new orders that include the code?
Delfonik
Warner Robins, GA
Here you go.
470072136246823
If you can't get a code to work, just try a different combination. I got the one above on the first try, so it's still working fine.
(PS: If for some reason the above code doesn't work, that means someone else used it. I removed it from my cart and have done this before for other users.)
bentleyrb
JohnKal, how were you able to change the required quantities for the Manville insulation? The Lowe's website is showing minimum required quantities when adding to the cart. Thanks.
JohnKal
New York State
I ordered the insulation that allowed single or multiple quantities. Mine was 2 @ $35ish. I then applied the code, completed the order then did it again.
Hope this helps.
Delfonik
Warner Robins, GA
cagullett1
North Texas
My zip codes did not show the same sale on insulation. But I did notice that my local prices are lower than zip code 38017.
fm2176
Down South
Statesboro, GA had a Rockwell Sonicrafter X2 for $49 on Thursday. Reviews seem dlgood and Menard's has a clearance price of $89. It's no longer available on the website and seems to be one of those items that only a few stores still have in stock.
zeekh
Upstate NY
I found one of those last night, I was torn on its usefulness so didn't buy it. I may go back and get one today
ETA: They don't show up on the website so you gotta go to the store and look for it. Lots of the PC cordless stuff is on sale in my AO
vahn
i want it :shocking:
Status
