My wife and I purchased our first home this summer and got married this September. Now that the wedding is over I've started taking apart and re-building my garage. We have a semi-detached home, with a 10x20 single car garage with a 9' ceiling.
I've been lacking with the photographs and I'm horrible for taking "Before" shots. Hopefully I can inspire someone else with a tiny car hold.
The second day we owned the house we were still sleeping on an air mattress, but I had a garage door opener installed!
The 4 CFLs you see were another earlier project that I added ASAP. Before there were 2 13w warm cfls on 2 seperate switches (one bulb/switch at the front, one bulb/switch at the back). I re-wired them to a 3 way switch so you can turn them all on from either side of the garage.
Here's what I have for before shots of the interior.
These photos were taken about 15 minutes into starting.. Shoot I forgot before photos!
Here's what I uncovered when I got to the man door:
Hinged off a stud, who knows what the heck is going on with the framing, right side of the frame is screwed through drywall. Wire runs around the header but through the studs at the bottom.. Not sure what the PO was thinking.
Here's the outside:
The flashing made it look pretty good from the outside, but upon closer inspection it was sketchy. The "sill" for lack of better term was actually below the porch. The brick was loose above and only barely supported. The door was the original door from the house that was moved over when the new man door to the garage was cut in. That explains why it was hinged backwards.
A family friend helped me install a new pre-hung steel door.
Here's the outside:
) - an open (walk-through) carport out front could be an option in the future, which would free up garage space.
