Rusty Bones
Houston, TX
Pulled all the drawers and slides from the Snap On KR657 I just picked up. I had to drill out every last screw holding the drawers on then had to drill out every rivet holding the slides in, what a pain in the A$$. Ran the slides through the parts washer to clean off 25 years of crud and see if there were any that were salvageable... Nope.. called Snappy, they're sending me all new slides. Now I need to sand and prep for paint.
Nexussian
Alaska
Were they ball bearing?
If not, can you upgrade?
k-os
WI
Finished sanding the North wall with 60 grit. Also started screwing the backsplash onto the workbench. Only put in a couple screws to keep it in place, was getting late and didn't want to annoy the neighbors with the impact.
rmalkow2
Brighton, MI
Since snow piles have finally melted enough to get at my poor F150 (sitting all winter snowed in) I thought to pull it out and park in front of garage to start the long awaited brake line replacement. Dead battery,ugggghhhhh!!!. So the battery is on the charger now to see if it can be saved.
Makoto
Houston, Tx
fixed the drooping hose real and relocated it to the center of the garage. also cleaned up the line for the maxjax.
also finally got a drill press.
k-os
WI
Got the North wall painted with two coats of Kilz. I think I may just leave it bare Kilz instead of painting over with a light grey.
bcos
I tried my hand at some garage art ... what do you think?
picture.php
bcos
picture.php
picture.php
I hope this works this time. Hung shop art. It was almost as frustrating as figuring out how to post a picture.
Bill
LWW
SF Bay
Finished installing the "Power Distribution" block on my welding cart. Now the power for my Millermatic 211 DVI and my Hypertherm 380 can just be plugged into the block and I only need to run one power cable from the wall!
I added a quick connector to the Hypertherm's air inlet so I don't have to fight with getting between the plasma and the C25 tank wall to attach the air line.
LWW
SF Bay
Also gave an old set of 6 Bose speakers, an old 10" JBL powered sub and an old Sony A/V receiver to a friend to free up space in the garage. Now I need to sell my Millermatic 175 "suitcase" welder and my Millermatic 210 "rolling" welder to make room for my TIG...
d4xycrq
Restored a Sheldon Thread Dial - was a bit rusty. Top of the dial was hopelessly pitted. Here's the dial assembly before:
And this is the dial itself after facing, being re-scribed.
The body of the assembly is completely rust free and will get a nice coat of Rustoleum Smoke Gray. Bits for restamping the numbers are on order.
Ray
Scot229
Minnesota
I made a cart for my welder.
<a href="http://s272.photobucket.com/user/evoscot76/media/DSC00567_zps8sfytdll.jpg.html" target="_blank"><img src="http://i272.photobucket.com/albums/jj187/evoscot76/DSC00567_zps8sfytdll.jpg" border="0" alt=" photo DSC00567_zps8sfytdll.jpg"/></a>
<a href="http://s272.photobucket.com/user/evoscot76/media/DSC00568_zpsjo7mjfqp.jpg.html" target="_blank"><img src="http://i272.photobucket.com/albums/jj187/evoscot76/DSC00568_zpsjo7mjfqp.jpg" border="0" alt=" photo DSC00568_zpsjo7mjfqp.jpg"/></a>
<a href="http://s272.photobucket.com/user/evoscot76/media/DSC00570_zpsawvuipu0.jpg.html" target="_blank"><img src="http://i272.photobucket.com/albums/jj187/evoscot76/DSC00570_zpsawvuipu0.jpg" border="0" alt=" photo DSC00570_zpsawvuipu0.jpg"/></a>
motorheadsdiygarage
Near Montreal
Two Front hub bearing assemblies replaced in 3 hours with no real struggles to mention. Now the HHR is quiet again!
Dealer cost to repair $750-$1000. DIY cost to repair $325.00 no labour added because I did it myself.
burnedzr2
Cleaned up and sanded a old craftsman 5 drawer base cabinet and gave it a brush and roll paint job with rustoleum hammered black drawer fronts and insides and safety red cabinet. It will work nice next to the south bend
greenjeepers
Arizona
Added a few more wire clamps to the lighting circuit and screwed the outlets in tight. Hoping to get the Final City Inspection in the next week or so. Also did a general clean up moved the battery charger to the next vehicle in turn. Need to start the work bench next.
jshillin
PA
I've been busy the last couple days...
Yesterday I swapped out my JL 250/1 for my 500/1 to drive the JL CP108 a bit better. I then ran all of the wiring to install a Punch 400a4 I had laying around to boost my mids & highs. Got all of that done and was installing a set of Pioneer 6x8's in the back doors because I had them for another project and never used them. Hooked them up and they sounded like ****... At that point, it was 1am so I called it a night.
Today, went to Best Buy, picked up a set of JBL 2 way, 6x8's for the back doors because I"m very happy with the JBL 6x8 components up front. Hooked them up, tuned my amps a bit and put the back of my truck together. I got a new Sirius unit for the Kenwood in dash and hooked that all up.
Next I put a tint strip across my windshield. All of the other windows were done when I bought the truck and it just bugged me that it didn't have a strip.
Took a 10 minute break to come in and throw a pork **** on the smoker, then back to the garage.
I then decided it was a good time to swap out my '08 F-150 Emblems for the newer style. I pulled all of them, cleaned off the adhesive, polished out the areas and installed the new emblems. Just came in and say down after a pretty productive weekend.
zcar751
Knoxville, TN
Started of just doing a little cleaning and organizing then I started looking at the drip pan under the Puma and I couldn't stand seeing the oil dripping of the motor. My original plan was to remove the fan shroud to check the oil cooler seals but once I realized I couldn't get it out do to some binding issues I decided to pull the motor. Well being that it is a two jack project with out a lift I had to make an emergency trip to Harbor Freight to pick up an extra floor jack so I got a nice aluminium jack.:beer:
View media item 48947
Once I got back to the shop thirty minutes later I went from this.
View media item 48191
to this.
View media item 48954View media item 48945
Here is why I pulled it. This spot formed withing an hour of moving the motor.
View media item 48949
And to top things off when I pulled the dip stick this is what I found.
View media item 48956
It's a thirty year old Brazilian VW motor dip stick. What do you think the chances of getting an OEM replacement will be.:dunno:
99LeCouch
Rochester, NY
Moved tools into my new box and cleaned up the workbench. Now my better half doesn't have to stare at my tools scattered all across the garage.
k-os
WI
Brought my friend's Seca II into the garage to pull it down to the frame.
Also picked up some insulation to put it on the single bay side. There's some older foil-faced insulation in some spots, but it's pretty ratty.
dcmus
Ardmore, Ok
No pictures but I painted walls today. Have lurked here for some time and spent countless hours perusing the various threads. soon I will actually begin a Shop Build thread but it's for a machine shop so my priorities are a little different:) Thanks for a great forum, it's a wonderful resource!
mopar65
been home off the road for 2 weeks been making some garage furniture.first is this reading light.base is a cast iron wheel from a company that closed in 1882. the light switch is a water valve gutted out with a craftsman wrench to turn it on and off.the light is from a really old studebacker
mopar65
another light this time a desk lamp.base is water valve wheel with an old gas pump nozzle for the stand and a headlight from an old ford truck
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Pulled the Hoopty out, pulled the Hoopty in. Swept the floors, screwed around on the computer, and got the snowblower off of the JD, and put the JD into the shed. Got the patio tables out of the house garage and back outside, plus dug the chair out of the shed to get back out. It was about 50 and sunny today, and tomorrow is supposed to be 70 and sunny.
Tomorrow is phone call day to try and find a competent contractor that doesn't want to **** a person on the price of a garage addition!!!!
mopar65
made a short coffee table from an old coffee grinder wheel made the column myself the base is off an old corn sheller
Kevin54
MEMBER EMERITUS
Urbana, Ohio
Holy cow Mopar.....that is just super uber cool stuff :bowdown: Do you make this stuff for yourself, or do you make it to sell also?
mopar65
made this pub table out of an old manure spreader sprocket wheel for the base the column is a crankshaft from an old 2 cylinder john deere extended some.the top is from a corn sheller top with glass
mopar65
another coffee table I'm making an old Desoto hemi that laid in the water forever.made an engine cradle for it painted block hemi orange.will get valve covers chromed then top with glass
mopar65
made this in honor of my late father the best dad a man could have asked for.the top is a wrench for when he was a mechanic welded to it is a hay hook for all the years he was in the hay business the block pulley and rope for his time in the navy.the old barn wood for all his years farming and the two wrenches on the sides were old wrenches he used
mopar65
had a dark spot above my parts washer so made this light to go above it
mopar65
and last what I did the past two weeks was finish this pump for my neighbor six miles down the road.been a busy two weeks
