Your media blaster and static electricity.
G19Tony
Las Vegas
I purchased a Skat blast that is on the way. I've used blasters in the past and always get zapped. TP sells a grounding kit that grounds the head of the sprayer. My experience is that I get shocked touching the frame of the cabinet with my arm. I was thinking of grounding the whole unit to a grounding rod I will place outside the shed.
What have you guys done? :thumbup:
mikegt4
sw ohio
I have had no problems with static on my **** Blast cabinet but I have using cabinets at work. A good ground couldn't hurt.
Charles (in GA)
50 mi south of Atlanta
I kept getting shocked with my TP Tools cabinet. I ran a ground wire from a screw on the frame (cleaned off the paint) to the electrical box (steel building and wiring in conduit, so everything is grounded) and it didn't do any good at all. I still get zapped.
Charles
9GUY9
Mankato, MN
I have my cabinet grounded and as long as I leave the piece being blasted on the grating inside the cabinet I dont get shocked. But if I hold the piece in my hand and blast it I will get zapped.
I have both a siphon feed and a pressure blaster setup in my cabinet. The pressure blaster does not shock me.
toplessHO
central florida
Ive never been zapped so dont know what Im doing wrong???
some guys have all the fun
I gave up on the cheap azz 12v florescent light inside and use a 500w quartz.
Yea it gets hot next to it,thinking of going LED
Lassen Forge
You may also need a ground clamp for the work you're blasting - I've been nailed hard holding something in one hand, gun in the other, and got Tazed. Saw the little ground strap hanging in the corner of the cabinet, attached it, and no more "surprises".
dladcock
North Carolina
^^^^^This.
A simple stranded wire with a frame clamp on one end and a clamp for the work piece will help. There are static-proof gloves for blasters, but for the money, a work piece ground wire will solve the problem.
BTW, our cabinet at work is designed so that it's possible a static arc can jump to a fellows nose if he leans in enough. That one is in a class all it's own.
dla
toplessHO
central florida
^^^^^This.
dla
blast out those nasty bouggies heh?
G
G19Tony
Las Vegas
That's a great idea, to ground the work. :thumbup:
I'm still going to ground the whole unit. :eyecrazy:
torqueman2002
SE Michigan
I'm running a TP plan/design, DYI wood cabinet with metal frame. Siphon feed, Craftsman shop vac, with a Dust Deputy cyclone dust extractor between the cabinet and vacuum.
Other than the grounded lamp/outlet/switch box, the other grounding is on the Dust Deputy. There is a wire attached to the 2 copper strips which runs to a washer which is in contact with the floor, like this internet picture.
I have not had any Zaps in the 7+ years of using this set-up.
I have been Zapped, when using the shop vac alone.
CoopVA
Virginia
Had the same problem. the Cabinet itself is grounded through the light circuit, but the nozzle needs to be grounded too, i ran a wire from the nozzle to the cabinet, and then to the building.
Cured the problem. also, as said before, make sure the part your blasting is grounded to the cabinet too...
There are pictures in my Garage thread...
Toxicscrew
Saint Louis, MO
Ground the box and the part as said before, you'll be good.
Sometimes grounding takes all the fun out of life, case in point:
I had a kid that worked for me once. I made him do all the blasting. One day he was blasting whatever and backed up to my metal spray booth. Took a zap to the **** he jumped higher than his chubby self ever had before I'm sure and let out a huge yell. He was much more careful after that. I had difficulty typing this as I'm laughing at the memory so much.
G
G19Tony
Las Vegas
That's how you learn. :bounce:
