ckadams00
I have an outlet in my shop wired from the panel. With a tester it says it is wired correctly, but I cannot find a ground wire; nothing attached to the green outlet screw or the box. This outlet feeds a second outlet through conduit and the second outlet says it has an open ground. Both are the same outlet style (ie the first in not an older two prong).
Any thoughts? I'm trying to fix the ground in the second outlet, but not sure the best approach.
I should also mention the second outlet then feeds two switches - one for an outside light, and one to turn the power to the outlets on - just didn't want to complicate things. . . .
