Homemade Shop vac hose reel
bagged89s10
CT
So I was searching for a shop vac hose reel and I saw some on Amazon, but they are really expensive. Then this video popped up in my
searches. This guy made a homemade reel using a hose swivel from an old vacuum. I thought it was pretty clever and seems pretty easy to make one.
LS6 Tommy
Northern NJ
Very nice. I have a canister vac we don't use just like that. Too bad I have next to zero woodworking skill...
Tommy
bagged89s10
CT
pretty cool. Construction is based on the water hose real ...... except made from wood.
You can probably find an old water hose reel on the side of the road on trash day to convert to a vacuum hose reel. Just need to find an old vacuum or a vacuum swivel.
kaffine
Henderson, NV
That is a nice setup.
Another option would be using a setup like hide-a-hose for central vacuums. It has pvc lines in the walls/attic that the hose is stored in you just pull it out and when you are done you cover the end of the hose and the vacuum pulls the hose back into the wall. Not sure how they seal the hose to the pipe at the wall outlet.
srmofo
SW ohio
That's a good idea and one I hadn't thought of.
For another idea that takes up a lot less space:
Go to rockler website and see their hoses that collapse from about twenty five feet to four feet and see the sleeve they live in.
I hate those especially for use on a tool. Because they collapse so easily, when you get even a moderate amount of vacuum inside them, they try to collapse into their smaller size
tcianci
Walpole, Ma
Man! You're really into hose reels lately!!!!!! :)
Dimarc67
Also working on a vacuum hose reel solution for my garage ceiling, and had already found Bellevue's video (fun and impressive). My wood skills are intermediate at best, so instead I'm going to try to adapt a wooden cable spool. (Home Depot sells them for $25 (!?), but they gave me one for free since it was a throw-away from their electrical cable area.)
Incidentally, the house we bought 4 years ago came with a central vacuum (works ok). The previous owner kept a 30' hose coiled on a hook in the garage, and also left behind two spare wall-mountable garden hose reels (molded from ABS). It didn't occur to me until I started this project that he might have been trying to adapt them for just this purpose. I took a look at them, and decided the ABS just isn't sturdy enough, nor easy enough to modify, for the larger hose.
Another thought that occurred to me is to put the reel in the attic above the garage, and simply create a collared hole in the ceiling for the hose to drop through--provided I can work out a reliable retraction solution. This would help address any pulling of the hose perpendicular to the direction of the reel, plus eliminate the need to make room for a 2' reel hanging from the ceiling. (Hanging the reel on a swivel mount would help with this, too, but then the stationary connection becomes even more of a challenge.)
I think I can create a swiveling pipe joint with non-matching PVC fittings, but I'll head over to the local vacuum repair store to see if they have any rotating joints. It also looks like many central vacuum hoses these days have a built-in swivel joint where they connect to the wall, so I may not have to cobble anything together if I can use that.
Will post again with success/failure tips.
gtae07
Fayetteville, GA
I don't know if putting a hole from your garage into an attic space (especially if it's attached to the house) would be code-compliant, or a good idea. Giving fire an easy path to the attic is a bad idea.
bagged89s10
CT
Yeah usually putting a hole in the garage ceiling is a no no according to code
bagged89s10
CT
I actually just picked up a long pool hose for $6 over the weekend. I didn't measure it let. Now I need to make a hose reel. I have an old vacuum sitting in my basement I might take apart for the swivel.
