packpride85
Just moved into a new house with a 20x20 2 car garage. There are some existing outlets in there (not many) so I'm looking for some advice on where to put some additional ones and what rating. Right now the areas where I want to put shop equip. is unfinished so will be easy to install.
I've attached a diagram of where existing things are as well as future items I plan to get. These are my first thoughts:
1. I would think the air compressor should be on its own circuit since it pulls 12A 120V and will most likely be cycling on/off while I use other items. Maybe a 30A with duplex recep on the side wall for it?
2. Another 30A duplex recep on the same wall further down for future things like drill press, table saw, etc...items that will mostly likely only be on one at a time.
The work table will use the 30A quad for table top items and a retractable 120V reel with tri-tap. Also will probably put in a nema 6-20r 220V single recep for a garage heater in the corner next to the quad.
