Strangest Place You Found a "Lost" Tool?
FullRaceMerc
SoCal (SGV)
Mine was a pair of baby vise grips. I looked everywhere. I thought. Finally gave up & bought a new set.
Years later, there they were. Still hanging on to that old rounded off brake bleeder.
Who knows how many miles. Tough little tool. Good thing they were on in a fashion where "Down" was tighten.
CJM8515
Not a tool, but I had a plug blowout on a 5.4L triton van. We figured out it was one of those insert type setups and had to buy the kit and fix it. 2 years later while servicing the van the mechanic notices something on one of the frame rails-the plug, insert and all!
MoparTrucks
Ozarks of Missouri
Er...medical call for a young woman with rectal bleeding....could see something up there but beyond rescue capability so off to the hospital she went.
Turns out it was a nice aluminum flashlight with a knurled handle......she was alone when it became...stuck and claimed she sat on it.
Ilikeike
Northern Ca.
7/16" wrench I found when a swaped an engine in my Chevelle. Lost it swaping headers a couple years before, it was laying in the frame cross member.
Ridwaan Gallow
Cape Town, RSA
A large star screwdriver..
Forgot it in the toilet cystern when i fitted it.. only found it years after when
the hose burst and i checked the whole cystern out again..
dlcwent
Member Emeritus
coastal maine
No one is going to top this one.:eyecrazy:
bigcaddy
Orange County/ San Fernando Valley
My first snap on wrench. I was changing out the battery of a newly acquired 1964 Cadillac coupe deville but didn't grab the correct size wrench for the terminal clamps. Something shiny caught my eye below the battery tray so I reached for it. Out came a 9/16 combo wrench...and was the size I needed for the terminals. The guy probably lost it last time changing the battery and never recovered it
I think the date code was a 1970s.
stubs
Bolton, UK
I've only ever found 1 tool that didn't belong to me, and it was a Snap On 1/2" drive ratchet (S936);
About 8 years ago, I was driving down the road approaching a junction and something shiny caught my eye in the middle of the road. I stopped the van just in front of it and got out to check. There it was just lying in the road - mint condition - it was like a gift from the Gods!
My only suggestion is that there was a truck repair place round the corner, and all the Snap On trucks used to get repaired there. Maybe it was lost by one of those guys?
FunkyfullWidth
Three Rivers, ma
I left a pair of vice grips holding my brake pedal linkage together on my wrangler for about 5 years. Forgot I put it there. Before someone *******, it was offroad only. As in my driveway or garage. No plates or hopes of plates.
MushCreek
Upstate South Carolina
I knew where my 8mm socket was; just no way of getting it out without tipping the car over. It dropped into a frame rail on a Toyota Corolla, and I tried for a long time to fish it out, but it had slid too far back. Yes- I tried jamming on the brakes, but it remained there forever. I tried wires, magnets, a shop vac, compressed air into the frame rail from the back, but it must have got hung on something.
devoncoolman
quakertown pa
Ive found many random sockets through the years. Mostly snap-on and always in battery trays and rad supports. Found a pair of gear wrench hose pliers laying on a manifold once. Non of them mine. Two days ago another tech found an oil filter socket in a toyota tundra. Ive been missing it for a year and a half. Looked in the history truck was last in 1 1/2 yrs ago for oil change and inspection. Yeah the tech was not me. Got my lost tool back that i didn't loose.
twertsy
Reedville, VA
half the time I search for a tool that I think im missing, its either in my back pocket or in my hand :-/
That little disease is NOT uncommon my friend............
I found a lifter INSIDE the rocker panel of my GTO while tearing it down. Full set of nut drivers and a couple screwdrivers were discovered in the lower side cowls. Still have no clue how that lifter got in there :dunno:
DocsMachine
A couple years ago, I was finally getting 'round to putting an Olds Cutlass carcass I'd had for way to long, back on the road. After dropping the engine in and getting it hooked up and running, we noticed gas leaking out the back- the hoses to and from the gas tank had dry-rotted in it's decade-plus wait out in the back forty. :D
Anyway, while I'm under there putting new hose on, I notice this:
Somebody had clamped a (knockoff copy) Vise-grip to the rear brake line, and then taped it in place.
Why? Your guess is as good as mine. The rear brakes weren't leaking- the backing plates were (and still are) dry as a bone, and the brakes work great.
Best I can think of is the dipwad PO had done it so he could do burnouts. Stand on the brakes (which would only lock the fronts) and punch it.
With a wimp 2-barrel 350 and an open 10 bolt. :D
Anyway, despite being knockoffs, the Vise-grips surprisingly still worked. I cleaned the rust off, gave it a dab of lube, and tossed it in the wreckin'-yard toolbox.
Doc.
reader2580
Minneapolis, MN
I lost an Estwing hammer and a pair of Channellock side cutters on a floor truss in my basement. I couldn't find either one for months so I finally bought new ones. Several years later I found them while doing some other work up there.
Ilikeike
Northern Ca.
I know there will be some home owners that find some nice klein strippers, dykes, screw drivers, and even a flashlight in their attics.
McFarmer
I found my 3/4 inch combination wrench in a feed bunk. It had to have gone into the silage wagon, through the blower up the silo, out the silo through the unloader and into the feed wagon out to the bunks.
mtnkid85
Wouldn't say it was a strange spot. But I found a magnetic pickup tool in the cowl of my wifes Pontiac. The car had just about always been in the family so I am sure it belonged to one of them. It had been in there at least 5 years when I found it.
Cleaned it up and put her back into use.
jonjon1
Having rebuilt my share of old hot rods {frame ups} I have found a bunch of stuff, but 2 stick out, 1 was when while stripping my 1939 tudor I wedged over the tank was an old ford wrench, looked VERY used, and most likely there from day one, someone must have dropped it or got it stock and left it there... I kept it with the car..
Next was a in a 69 super bee, removed the rear seat there was an old Sun timing light , remember the long chrome ones... My son spotted it first he was about 11 at the time helping me strip the interior out and he said "woa, a tazer gun"... lol, I always told him restoring an old car was like going back in time, I can only imagine what his little brain was thinking, I wish I took a picture of his face when he seen it...
03protege
Louisiana
2 years ago when I was swapping the engine in my Protégé I found a screwdriver in the radiator support and a socket somewhere else in the engine bay. Both of these tools were in the engine bay for 6+ years and surprisingly looked great. The screwdriver had some minor rusting socket looked as good as new.
The only other tool I lost was my 12mm Kobalt usa impact socket, after buying a non-matching Taiwanese replacement and going to use it I find the "lost" one still attached to the impact extension.
chris142
apple valley,ca
Is a Flashlight a tool? I was out looking at Gold mines. I left my Blue maglight on the bumper of my Jeep. It was originally my dads and he always put a paper towel inset into his flashlights, sposably to keep the batteries from rattling.
I went back a week later as it would have fallen off right where I was. Tons of ATV tracks were over my old tire tracks.
A little bummed I left the mine and went home.
About 3 yrs later I was out jeeping about 40 miles from where I lost my Maglight. We were on a good dirt rd but that rd crossed a part of the Mojave 250 race course. The course is just 2 big ruts with 2 big berms on either side and a smaller berm between the ruts.
Something caught my eye. My old Blue maglight with the paper towel insert was laying in the dirt. Must have bounced out when someone hit those berms.
txvwnut
Bedford, Texas
Smart *** at the factory put it there. Had a cavalier come into the local Chevy house for a thumping noise during acceleration and braking. Took three months of warranty work till the dealership owner came out told the car owners to pick another cavalier off the lot. The current one was then cut in half at which time a large ball bearing comes rolling out of the rocker panel and a note was found inside that read "took ya while didn't it".
That guy has the same twisted sense of humor I have.
MFolks
Springfield Mo.
I was rebuilding a large machine, and had a socket(5/8th I think) pop off the extension, figured it was on the concrete floor. Looked under, around, even took a broom, and swept in places I thought it might be.
Finally was going to say "Good Bye" and go and get another, but noticed a hole in the machines frame, got a extendable magnet, put it inside, and heard a "Click" & removed the missing socket. Now, I could not have duplicated that vanishing act again if I tried!
BearsFan315
Portsmouth, VA
was doing some fall gutter cleaning a few years ago and about half way down the gutter run on the back of the house i found a pair of 6" craftsman pliers. Funny thing is they are the ones I lost a year or so before and could NOT find, i looked everywhere, turned the garage upside down inside out looking for them more then ONCE !! ended up buying a 4pc set on sale so i could replace that one. 4pc set was on sale cheaper then just the 1 plier I needed, and never can have too many tools :!
i just chuckled took them in the garage cleaned them up and put them in the drawer with the new ones.
make matters worse I do not even remember WHY I have them up there in the fist place ?!? what was I doing with them up there ?!?
dodgejunkie
Not me, but about 30 years ago an exhaust guy at our shop turned the entire shop over looking for his 5 lb dead blow! He questioned everybody and swore somebody stole it. About a day later this guy shows up at the shop wanting to know who Vince was. I questioned him why? He takes me out to look at his car. There's the missing dead blow with the handle sticking through the passenger area of the windshield with Vince's name proudly blazed in the handle. Apparently Vince had left the hammer on the leaf spring and fell off becoming a projectile going through this guys window. He was able to get the car stopped that it came from and put 2 & 2 together... Luckily nobody got hurt besides Vince's pride and wallet.
Cope
Houston, TX
My wife had a new 1977 Dodge Aspen wagon. I was looking under the hood one day right after we got it. Spotted something out of the corner of my eye, an Apex driver bit wedged behind one of the nerf bars on the bumper. Found a similar bit under the seat of a new car in the showroom.
bwringer
Indianapolis
Found a nice green Mag lite flashlight in one of my gutters.
I still haven't quite figured out why anyone would need a flashlight on a roof, exactly, but I'm sure there's an explanation.
I also found a nice Blackhawk 3/8" ratchet and a very useful shorty extension under the hood of a friend's Lexus. I think I was replacing a belt or something. She told me to keep the tools as a bonus.
My personal best was when my wife started complaining of an irregular metallic tapping noise coming from somewhere in her Honda motorcycle.
I searched in vain for the noise for weeks -- I couldn't hear or reproduce the noise, but she insisted that it made a noise when she rode the bike. Sanity was questioned... there were no tears shed, but there was a snit and possibly a huff or two...
It turned out to be a 10mm wrench wedged on top of the engine in such a way that it tapped against the swingarm when she was riding the bike. When I rode it, the swingarm compressed further and it didn't tap.
The best part was that I had lost that particular wrench about three years earlier. No idea where it sat for so long before finally getting wedged in the exact perfect place to drive us both nuts and defy diagnosis.
M-EGT
PHX
I've found a few screwdrivers and wrenches that I put near the hinge of the hood, close it, go drive it, and then find it later - sometimes days later.
Zeke
Pliers, out in the garden. Had been there at least 10 years. Always wondered where they went. Actually, that's happened 2wice. Once at my previous house.
I found some small scissors in a tool case I had in a Porsche that got sold. I swore my wife had lost them. Whoops.
Still waiting to uncover a jewelers loupe.
geojag
Little Rock, AR
Changing out a fan at the house we bought, found a pair on Krauter linesman pliers buried in insulation. No telling how long they had been there.
I have found tools (sockets, wrenches, screwdrivers, mostly junk) in pick and pull junkyards quite a bit, I always turn them in to the owner. They always claim that they had been looking for it, although I highly doubt it is their tool 90% of the time.
Generally if I loose a tool, I find it as soon as I replace it.
Bagherra
Virginia Beach, VA
Found a 3-cell Maglight and pair of sunglasses in the tailboom of a UH-1H...
6" 1/4 extension on the hydraulic deck of a UH-60...
Not mine! Both found during pre-flight inspection..
Rockhead261
Dropped a brand-new 13mm 12 point socket into the black hole between the battery and the frame on my Harley Electraglide. Pulled the seat, battery, tank, side covers, moved all the wiring around... nothing. Put it all back together and made a few hard starts/stops. Nope. A year later I'm doing PM and the socket dropped onto the floor when I pulled the air filter cover. Never heard a rattle and still can't figure out how it managed to get there.
NewEdgePerf
Found a 30 inch MAC pry bar between the twin I-beams of an old Ford Econoline that had just come from the auto auction.
