CwazyWabbit
Now if we were to loosen it to include clamps/cramps I'd be there and back in my sleep!
Whilst this one isn't going local it is going to another forum memberI don't know about you but when I sell one it's like a part of me goes with it. That's why I try to sell local.... maybe I can go visit...
I use AC, I did repairs to the last Record 36 I cleaned up (this is a cast steel vice) and it worked well. You can get some rubbish come out of the casting that you may have to stop and grind out but you can get that with welding it as well.
I think it was one of Jody's youtube videos that I first saw it used on cast iron.
http://www.weldingtipsandtricks.com/welding-cast-iron.html
EDIT: Just to add this page of his gives a bit more detail on why he uses AC http://www.weldingtipsandtricks.com/tig-welding-cast-iron-409.html
I keep both on hand, both are Harris rods designed for TIG, which have a different composition than their gas rods. I always run the Si rod on DC and usually run the Al rod on AC. There are a few different alloy compositions of the Aluminum bronze rod, off the top of my head #2 is the one to use for buildup and joining. There is a company out of Michigan or Wisconsion that specializes in copper based fillers for the MIG and TIG world that had a good rundown sheet on them.:
A friend sent me this link and said, "Hey, it says Wilton vise..."I clicked through the photos and didn't see anything but it does say, "160 pound Wilton vice, $350"...I emailed the guy asking for more photos. He sent me this.
Looks like a 600 in good shape. It isn't a great price, but it is a rare-ish Wilton if someone in the area wants to try to make a deal on it. It's too far for me...
Thanks for the links CwazyWabbit, good informative read. I have never tried the copper based rods on Cast Steel and will experiment on a few scraped vises.
I always used AC for the copper based rods even adding the Si/Bronze to steel. I have not used any Al Bronze rod and thanks for the Harris tip, they have what I want but 10 lbs is to much for a minimum order. I liked to add Al/Bronze to steel wear plates like the Parker collars I am making, maybe later. Thanks guys for the info.
Would this vise originally been equipped with a swivel base? Or were some sold with and some without a swivel base? How does either configuration affect value? (Please, someone talk me into not making an offer on this vise.)
Swivel base was optional. 600N was the model without swivel base 600S is with swivel base. Wilton used a clever design allowing the same main casting to be used with or without a swivel base.
Never seen a bar worn like that, was it rattling around mounted to a truck?.......![]()
Funny, people keep saying things like that, or have her call before they hold my estate sale!TM: so just want to give you a warning like we tell the guys visiting the Craftsman block thread. BEEEEEE CAREFUL because these guys get bigger and they all want to follow you home. have you found that lot yet to build your 40 x 120 garage/shop yet in case Mrs. T doesn't agree with your love for great old tools?
cheers and nice solid Holland's vise. that handle is a bit different and looks a little like some of my dumbbell handles.
Reed vise in the daylight. I cannot see any model number.
Plan is to get the pressure washer out, give it a serious bath and start my learning on how to prepare for painting and lube.
Local machine shop has a 4' chunk of 6" sch 40 that should work for the stand after I weld up some spokes on it and pour a concrete base. Or can I simply use an old bigass rim? This is damn heavy.
Any other options you fellas have for this, please give me a lesson.
Thanks
Bill
B100: do you have a catalog page for the Vanderman vises that might be different than FMC's because i thought i saw that the #3 was heavier?
Thanks for the response, zkling. So I'm assuming that if they used the same housing, "600" is all I'm going to find cast into the housing, with no way to know if it originally was a swivel model?
Come to think of it the only one I'd consider splitting due to weight isn't a quick releaseI bet you'd travel for a really big vice at the right price
One of the problems with lifting the 48 is finding a decent place to get hold of it, it's quite curvy and if you grab it low down it gets a bit unstable when lifting it.
...The photo is the difference between a Wilton 500N machinist vise and the 1755 "Tradesman" series...
That's a fabulous bench and vise mounting system. The quality on that looks top-shelf.![]()
Balane, how many years have you been restoring vises?
