I picked up this Rockwell/Delta 28-365 20" very-speed bandsaw last weekend and after getting it into the shop had to leave it sit until today, I was out there and gave it a better once over there are a few issues that I know I have to tackle before I can get it cutting.
The first is what VFD do I need to convert the single phase to 3 PH? If anyone can point me in the right direction.
Stats on the motor.
1.5 hp 3 PH 1725 rpm.
The next issue I am sure I can handle on my own, when I pulled the switch I noticed that the insulation is in poor shape with cracks and missing chunks. Just a matter of picking up the correct wire and installing it.
2 other small issues I have found so far, the bolts for the trunion are a bit galled so I will have to pick up 2 7/16 x 2 1/2 inch bolts with matching nuts
The handle for the high/low range selector is missing as well so I will order a replacement that looks ver similar to the one on the FPM hand wheel.
I do want to make this a plug in unit, so if needed I can make use of the outlet for other things, so I will need to install a cord and plug any idea what gage cord and which plug/outlet combo I should go with.
More pics.
Stats on the motor.
More pics.
