Sure shot?
HotFry
Arizona
I like mine.
Fill it up 75 to 80% full, pressurize it and away I go. Get a lot more life than the airisol cans for sure.
jrcampbe
It's a very high quality piece of equipment. You won't be unhappy. I keep mine filled with the garage journal 50/50 acetone/ATF penetrating oil.
Edit: I don't like having brake cleaner in my shop. It is extremely dangerous stuff.
Fedwrench
Valley of the sun
It's completely rebuildable aside from cracking the tank from a major fall. 5 gallon containers of brake clean may seem expensive at first but, they'll last much longer and generate less trash then the usual aerosol cans. i wouldn't want to be without one or two. :thumbup:
O
OHMS LAW
Houston TX
I want to get one but I may get it from Amazon since our snap on guy sells them for double what they go for on Amazon.
Mohawk Dave
SoCal
I wish I would've bought my sure shot earlier.
I have WD40 in it for cleaning up old stuff I bring in to restore.
I need to get a few more for Brakekleen, Triflow, and ATF/Acetone mix.
Fretters
South Yorkshire, England
The stuff you have over there can be. Far as I recall though, European regs ban some of the ingredients from being used elsewhere, so brake cleaner is safe, though still quite flammable, stuff over here. This point crops up occasionally in regard to welding when brake cleaner has been used on something.
Lassen Forge
Makes Phosgene gas. Think WW1 and Trenches. Nasty stuff! And the damage it does is irreversible. :scared:
Before I knew that, I used it to clean a lot of stuff. Now, I rarely (if ever) use it - still have about 3 full cans of a case I bought a couple years ago. The Sureshot is a way better way to go - plus, you can fab up your own component mix.
