So ~1/2" deviation per the contact points per stand, ~3" between the stands. That is pretty minor, but as you increase the height of the stand, you increase your chances for problems in tip over, sliding and breaking the stand. Did you read the other thread in its entirety?
I did..
Is there anything I can put under the car (only lifting one end) that would safely catch it, if it fell?
When I jack up a car on somewhat unstable ground (side of road, etc) I side the tires under the car to catch it if it fell.
If you aren't removing the wheels then putting ramps under the lifted tires works, even if you lifted with a jack.
I'm not going to second guess a set-up I've never seen, but if you're unsure, maybe just some regular ramps would work for you. BTW----I made my own out of solid layers of 2 x 12 staggered and beveled and glued up. You could drive a semi on them without fear because they're.....well......SOLID! :S
Seems pricey. You can build some tailored to the height you need for just a few bucks:
As one guy, i forgot his username said (the engineer) the uneven surface causes stresst on the sides of the jack. The jack supports could support x tons vertical, perpindicular to the ground, but nowhere near as much when you shift the angle of the jack. Just proceed with caution.
.OP . . . . . why haven't you blocked the rear wheels both sides ???
Is Parking Brake set ??
Drive-on ramps (ie solid steel or plastic) would work fine on driveway slope. Once up on ramp, then block behind those front tires also.
* * * * * OR * * * * *
To determine angle, you could hold Level vertical along with T-bevel/Angle Finder and cut some pieces of wood in wedge shape to put under your jack stands.
http://www.lowes.com/pd_466699-5600...L=?Ns=p_product_qty_sales_dollar|1&facetInfo=
How did you get the vehicle so high? It looks like my tires sag about 4" when I jack up the car. Not many jacks go over ~20", and (again, my car) the seam is about 9" from the ground.
That means I can lift the car 11" from where the tires are, but I only get about 7" because of sag. Did you use a separate jack to press the suspension up?
Put your jack under the lower control arm or rear axle. No sag and you don't need a separate jack.
(BTW, pic is not my car)
Well, one of them is now stripped - despite me using penetrating oil over night, and starting it by tightening slightly. I also tapped it with a mallet a few times, worked it back and forth and then waited, etc.. I have to get the head fixed, now - which means removing it.(I don't trust the repair with head on block.)
Unless the plug is all the way at the back where you can't reach it well, I'd recommend not removing the head and doing it on the car.
What kind of car?
Well I'm only a physics student and mechanic, and am now an expert. It theoretically sounds decent, too lift it, use a jack to lift a corner then slide a jack stand under it, put the wood under, remove the stand, then lower the jack slowly. So put it on stands for a min. then slide the wood under and release. But please proceed with caution.Yeah, I'd like to do something safer. I'm thinking about a solid (not stacking) 12" version of what the gent above me has, and torsion box style with stronger wood.
But I'm not sure how to get the vehicle up and onto it.
