topop101
Before I mounted the parker I just picked to be my working vise, I had a Wilton 4 1/2 or 5 inch from the late 80s maybe and it worked fine, they should be around used if patient
Hi Vise Friends,
Does anyone have information about the vise pictured below?
How old?
Who was the manufacture?
Thanks in advance.
Automotive use, so steelWhat style are you looking for? Very easy to make a smooth set out of aluminum, brass, copper, steel.
. You need to have VA add it to the manufacturer data base !It is now a " Wilker ".
The worst part is the missing jaw inserts and damaged jaw perches. I have some CRS big enough to make a pair of smooth jaws, but no way to machine the perches back true to accept them.
TP and ALL: i'm not a huge fan of the open screw vises, but i know there are some i own and have on my list to buy if they show up. so my question is do you guys grease or oil the open screw? also do you all put a wet or oily rag over the screw when cutting or working on something inside its jaws so crud and shavings don't get in the vise nut via the screw?
Hi Vise Friends,
How old?
Thanks in advance.
Doing some work yesterday that involved me heating a part with my cutting torch while my dad beat them into shape with a bfh. The china record worked, but a better vise would be nice....
Have you tried doing a search for the logo? Haven't done it myself, but I hear that there's a way to search online for photos matching an example - maybe on Google? Try to get a better photo, with side lighting to make it show up better, or make a line drawing and use that.
The keystone suggests Pennsylvania, but I have no idea what the I might stand for.
Good luck!
Yeah thats a good point. Used them loads in the blacksmith shop at the local farming museum. Hadn't considered one on the welding bench, but thats actually a real good idea. That is the only vise that gets beaten on like that. The other two in use are English fixed base 4" records, that are usually just holding pieces for center punching, tapping, or filing. Permanent soft jaws in one.Sounds like a post vise would be good for you. Otherwise you will probably destroy a standard bench vise in short order.
Hi Vise Friends,
How old?
Thanks in advance.
A harbor freight will do the job .... once ... twice maybe more??? Or you could check your local cl for a time tested vintage vise that could be ready to bolt down or have a blast restoring then bolt down and go to work. Any brand pre 70's should do . My fav working vise is a parker 954 or 974. Lots of them out there and are as good as any in my opinion as if that matters.
ALL: i should start a thread on broken vises so other members might know that a big vise can break and not just the new imported vises. anybody saving pictures of broken vises and welded ones because i only have a few?
Guys,
Thanks for the guidance on my mystery vise. The "Keystone" was my epiphany. I think that I can guess that it is a Hollands malleable iron vise. Circa; early 1900s. Here are a couple of attachments:
Anyone recognize the size on this one?
http://neworleans.craigslist.org/tls/4954537029.html
Maybe I don't know enough yet to see what you guys might, I just see the obvious - swivel bullet, no idea on size.
Agreed as to size. But I would not argue the price to much. That is a fair, no make that a good price.I'm guessing 4 or 5". I would go see it and buy it. Try to negotiate a few dollars off.
~Veeps
Guys,
Don't know what company that vise represents with the big I, Mark, but I wouldn't be afraid to bet a Grant that Hollands made it.
Be no different than a Columbian--Rigid, or a Rock Island--Craftsman.
Edit---Posted late.---See you already came to that conclusion.
Well which is it, Wilker or Parton?---I got's to know before I can plug it in.---How about Wilpar.
Were any of yaw watching the little generic Wilton on E-bay last night.---I through in a bid and figured I'd way over bid.---The final made mine look like tip money.
http://www.ebay.com/itm/Lot-Of-2-Vi...D&orig_cvip=true&rt=nc&_trksid=p2047675.l2557
Good research. Here's a Hollands Keystone for sale in NY for $30
http://hudsonvalley.craigslist.org/tls/4917771047.html
That one has been for sale for months, somebody in the area give it a new home.
I guess Balane will have to decide what his new vise will be named ? He has probably been up all night finishing it and waiting for proper lighting to get the stump pictures done![]()
