Useless wrench?
icor1031
SD
I bought a 24mm wrench, to disconnect a fuel line that has a 23.89mm nut.
The wrench I got (tekton) is 24.25-24.30mm, and I'm scared it'll ruin it because of the play.
Did I get a dud?
gorilla
The difference is only .018" I'd say that's about normal wrench clearance.
bwringer
Indianapolis
That's a normal and necessary amount of clearance.
You could try a 15/16" wrench (15/16" = 23.81mm) but honestly when you're down to fretting about tenths of a mm, you're way past the point of normal manufacturing variations.
I
icor1031
SD
Worst case shim it.
I had thought about that, I may; glad I don't need to send it back, though.
But the difference is almost 5/10th of an mm :lol_hitti
I was concerned only because there was more play than I normally have.
jonjon1
I notice with the larger sizes the "play" between fastener and tool is larger. I wouldnt worry about that..
DodgeMech
And the nut/bolt generally doesn't care either...so long as you're within an 1/8 or so, a wrench or socket should work haha
fattogatto
Put a layer of metal tape on one face and try it. If still loose put a layer on the other face.
Dave.R
Grand Rapids MI
All the wrenches will have a slight tolerance to sizes. In a perfect world if the nut was exactly 24 and the wrench as well, it would be a heck of a time to get the wrench on it. Wrenches, sockets, and anything else that has to fit a fastener will generally be very, very, slightly larger to allow for variances in fasteners as well as damage.
With a fuel line I'd use a line wrench, but that's because I'm in the rust capital of the world.
Dennis Leigh Henry
South Central, IN USA
How much torque is needed to untighten / tighten? That's another consideration... If its lite.. I suspect it'll be ok. If its heavy... it might become a problem especially on a soft nut/head...
BFBOB
Ditto trying an SAE wrench (line wrench if you have it). Just yesterday, I went to change a PS hose, thought the 16mm wrench felt sloppy. Switched to a 5/8", nice snug fit.
In this case, it's a 91 Explorer which has a mix of Metric and SAE, so no idea which was the "right size". Go for the best fit.
Squankum
Southeast
In addition to the above advice, this can be a good situation for a Knipex pliers wrench. It's like a crescent wrench but without any slop. Heck, thanks you guys here at GJ, I've found that quality crescents aren't that sloppy anyway. But the Knipex is zero slop.
I've found myself reaching for that Knipex when dealing with fittings that don't seem to be any particular size.
Ben Buck
S. W. Ohio
Would my Channelock metric adjustable be of assistance?
It has the ability to get close tolerances ?
