Strouty
Another update, no luck with anything so far. The corners were pretty much gone so I drilled a hole through the plug and put a bolt in the middle and pried / hammered on that, just bent the bolt. Then I cut a notch and used the chisel, just broke more off. I did get some Kroil and used more heat / air hammer, I thought while I was heating it I noticed something bubbling from behind the threads, not sure though. To be honest I think I knew I would need to drill it out. My biggest concern now is I am going to cut into the threads and or get a large piece stuck in the tank. I was going to do as suggested, drill a hole, saw as close to the threads as possible then use chisel / hammer to collapse the piece in, and hopefully pull it out. Any nuances to doing this?
Because the plug is cast iron, you don't need to be as close to the edge as possible, just get near it. The key is to make at least three cuts, think slicing a pie. That gives the plug space to move when you hit it and the cast should break off. If it doesn't break off, you can always cut another slice or go a little closer. As for the people who are saying it isn't easy, the threads will get destroyed, or you are going to get pieces of metal in the tank, well they obviously have never done this.
Also, the propane torch is not going to do anything, accept waste propane. Get yourself a bottle of mapp gas, that will work much better. O/A would be the best, but you can easily buy a mapp gas cylinder and use your torch head.
