tips for cleaning wrenches
jonjon1
I was noticing on the wrenches I dont use much they are getting a bit dull and some even have the starting of bumps, what is a good method of fixing this..
Or products that you use?
hangfirew8
Central Maryland
Use a microfiber rag, like the kind for car detailing. I find the AmazonBasic ones good enough, I'm sure there are better- for more money!
A shot of brake clean can be used for tough degreasing, especially before those "show us your toolbox" GJ threads. :)
Bumps? Either peening or rust, I just leave that, it's the mark of a tool that is earning its keep.
Bondo
Greenfield, Maine
Ayuh,..... Use 'em, get 'em good 'n greasy, then wipe 'em off with a rag,....
J
jonjon1
seems the ones i use all the time are fine, its the ones that go a while with out being touched like the half moons, s shaped, offsets, and odd sizes...
Bondo
Greenfield, Maine
Wipe 'em down with the same greasy rag, when yer puttin' away the wrenches ya used,....
Dave455
Sussex, England
If you use 'em regularly, clean them with a rag and a squirt of WD-40.
If you don't use 'em regularly, get them out once in a while and give 'em a wipe as above anyway!
I've started storing the stuff I don't use so often in long shaped kitchen boxes. That and a wipe of WD-40 and no way will there be problems! If you leave 'em on a board or suchlike, they'll take more looking after!
ProCharger
I have a mechanics set that got rained on, fearing rust I coated them pretty good with oil. Those things got so dirty over time...before I put them into my new chest recently (do not tell my wife) I ran a bunch of them through the dishwasher. Look as if they were new.
Adam.C
Clean your chrome tools with a ball of aluminum foil.this makes a great polish. Rub hard until the foil turns black. A light coat of light mineral oil like 3 in 1 is a good finish.
bagged89s10
CT
Haha dishwasher
~Veeps
doan
Frisco, TX
Nothing but oil or WD-40. If they already have rust "bumps", some 0000 steel wool will knock it off.
Murphy4570
West Deptford NJ
Keep them greasy. Clean them with a rag, leaves a thin film of whatever you were working on. The only problems I've had were with impact and power tooling, where they are black oxide coated, similar to a Parkerization coating. They do rust from moisture in the air over time if left dry. Keep them wet with a thin oily substance, like ATF or a similar 10 weight oil.
LUKE221
TEXAS
For greasy sockets, i leave em in a mix of simple green and hot water for twenty mins and then i take the old toohbrush to em. Extremely important that you get all the water out of them immediately
Wizzard
I use the big spray can of RemOil (~$6 @ WalMart in firearms cleaning section)...works well at cleaning off light surface rust and it works well as a rust preventative.
2oolhound
BC Canada
Not a good idea. Many of the additives in modern oils are pretty bad stuff, specially synthetic oils. Then there's lead and other nasties that's always wearing off inside your engine and mixing with old oil. If this happens again your wife will be notified.
Ponchoguy
Spray with WD40 and wipe clean. Good as new. I clean them that way and it works great, and I have some old wrenches.
