Do you have a rosebud and a set of torches? I could give you a layout as to where to put some pins, or some templates to cut some wood to make a wooden jig so you can drop the bar in and work it around. If you use something like some a 2x12, and some 2x6's, you can make a 1x use wooden jig. Fasten the 2x6's down to a 2x12, or even down to some plywood.
I'll help you out anyway I can as far as drawings. If you want to put some dowels into something, I can lay it all out for you, no problem. I have torches and tanks, but by the time I got the material on my end, made a jig up, bent it up, and then shipped it, someone on your side of the border could probably do it cheaper.
But if you have tanks and torches, make a wood jig up, and bend things to that. The longer your barstock, the easier to bend it once you heat it up cherry red. Keep the jig wet and you may get a couple of pieces out of it.
