New to me old lathe
coby65
Monterey Bay area
Ok a friend of mine is retired and he and his wife are going sell the house and hit the road for a couple of years.
He gave me this old lathe and I have never messed with a lathe or a mill.
I need to change the plug for the 220v to the one my air compressor uses and I need to get the cord to the mill head spliced back together.
Any web sites I should check out or how to get started playing with this?
Where can I get parts and tooling.
dr_clyde
Holland, MI
I would check in with the guys at The Home Shop Machinist. They're by and large a good bunch.
littlemachineshop.com has tooling and stuff for the hobby machinist.
Practical Machinist is a great forum and full of good info, but be warned. It is a forum for professionals and they do not tolerate discussion of home shop machinery.
zkling
It's an older Emco Maximat, google that and you will come up with a plethora of info. They are a pretty nice machine if used within their design limitations. Cutting tools are generic. Read up on how to sharpen and use HSS lathe cutting tools. South Bend's "How to Run a Lathe" book and the Atlas "Lathe Operation" are good books to start with.
C
coby65
Monterey Bay area
Thanks for the info. I will check out those forums and Amazon the books.
The Lathe is a little dusty and stiff to move the some of the components. What do I use to clean 20 year old dust/oil mix and then what oil should I use after?
royesses
Join The hobby machinist forum. It is the most friendly and informative there is. They will bend over backwards to help and train you. Many downloads available.
http://www.hobby-machinist.com/
Congrats on your new to you lathe/mill. You will have many years of enjoyment if you get into it.
EdT
North Georgia
For the clean-up I'd suggest starting with WD 40 and a non-abrasive scrub pad. Spray it down and let it sit for a while.
larry_g
oregon
For cleaning I like to use Hoppes #9 gun cleaner. And whatever you use to clean it use no abrasives on the ways or other moving parts of the machine. That is a highly regarded European machine, Austria I think. Check the gear train out an you will find some plastic gears. They work well but are like a fuse and will strip if you try to take to much of a cut.
here is a google group that is said to have manuals posted, https://groups.yahoo.com/neo/groups/emcoV10lathe/info
lg
no neat sig line
A_Pmech
IL
What do I do with slight surface rust in some of the areas?
A little Scotch Brite and WD40 will clean that off. Do one side of the machine at a time so you don't get the abrasive slurry under the carriage ways.
C
coby65
Monterey Bay area
Thanks for the advice from everyone!
It is made in Austria and seems like very good quality.
I think I will get it outside and use brake cleaner to get some of the oil/dust gunk film off and then follow up with the WD40 and a fine scotch-brite pad for the surfaces and rust areas.
Electrical will be the next hurdle. I have 220v for my compressor with the 3 prong plug but this has 4 prong plug that says 30A 227/480v 30y. I can not get to the back panel yet to look at the voltage specs so that will be next.
454ragtop
Carver, MA
Don't assume it is 3 phase just because it has a 3 phase compatible cord cap on it. Confirm this with looking at the motors.
lg
no neat sig line
Didn't assume, note I said "sounds like" and asked for more easily obtainable info. Now that I've seen the tags, I'm thinking it is 4 wire 230 volt single phase, with 2 hots, a neutral, and a ground, so as to be able to pull 115 volt off it. Probably best to ask on the group that was posted, since I can't see phase called out anywhere, but I suspect it is single phase. OP, help us help you and rotate your pics before posting please.
Jim
C
coby65
Monterey Bay area
Apologizes for the picture orientation. Trying to do a few things and talking to DW at the same time. I took a picture of the plug it has 5 pins and is on the left
C
coby65
Monterey Bay area
Just wanted to add the WD40 and scotch-brite is working great. Not using a lot of pressure and wiping it with clean towels before moving anything.
Thanks!!!!
C
coby65
Monterey Bay area
took the plug apart and there are only 4 wires so one of the outer pins has nothing hooked up to it.
After cleaning everything moves easier and alot smoother!
