Show your new tool arrivals
RumT
PDR Kalifornia
My new Lincoln Power Mig 210 MP arrived. I found the little Craftsman roll cab on CL for $50. It will be integrated into the welding cart I will build.
mikeselky85
New Castle, Delaware
Nothing special. 1-1/16 and 1-1/8 crows feet, only because I ran into a bind and needed them.
Will say, I'm not a huge fan of the etching on these......
90zcar
I wouldn't have even bought those since they didn't have stamping. U said u were in a bind tho so I understand
Strouty
Southern Maine
Craigslist find. At first I went and looked at a Gardner Denver 1-1/2hp (probably) decided it probably wouldn't be enough cfm for me. I think this might do the trick.
No motor, which was fine as it was probably 3ph anyway. With the pressure lube and lifesaver feature of the Dresser, I might put that one into service. With a 7.5hp motor @125psi I should be almost at 40cfm :)
How can you get 40 CFM out of 7.5 HP? I was under the compression (LOL) that HP and CFM were essentially a direct relationship? If there is a magic trick to pull 40 CFM out of what would normally be 25 CFM, please let me know, I would love to be able to get more out of my compressor too.
G-Ram
NWO
Been on a Jet buying spree lately, figured I'd try out one of their composite impacts. My IR 231 is getting tired anyways...
Bobcat753
New Hampshire
Don't you dare cut up that nice craftsman box! That's a nice vintage piece there!
Also nice welder.
mikeselky85
Yeah..... Only cause I was in a bind and needed them. Any more I will most likely go with another company cause that etching really doesn't sit well with me
csmitty
Your right, I was looking at the 10hp. Still should be in the 30s with 7.5hp though with some interpolation from the 250psi bracket. Given less psi = more cfm.
90zcar
Yeah it's a shame because it's not really a big deal but when u pay the big money for snap on tools you never expect to see etching.
BTMSUP
Milwaukee, WI
Haven't had any issues with my etched stuff?
Me neither, not once, not ever. I have Mac, snap on, and matco stuff, all etched and it doesn't seem to affect the quality of the tools at all.
I am however a tool user, not a polisher so I don't get too worked up over those things.
90zcar
Problem is I like to be able to see the size and when something is etched....after a couple years of use the etching goes to hell. I can show a couple examples of this next time I'm out in the garage I'll take a picture or so
WhiffySpark
You can say the same thing about engraved stuff. Half the time it takes me a few seconds to read sockets
Deadsquiggles
Chesapeake, VA
Picked up the 10 pc Allen socket set, 4 pound long handled mail, both from Northern Tool and made in Taiwan. Plus my 3 Carhartt t-shirts came in the mail. I love when the big brown truck shows up in front of my house.
GTA Matt
Zebulon, NC
More stuff for my home shop: otc slidehammer set, sk piston install hammer, Mayhew race punches, AP race installers, Mayhew scraper and pick set, torque sticks, some cheapy snap ring pliers just to see how they work and some roloc disks.
iajonesy
Iowa
GTA MATT, do you have the part number for the OTC slide hammer set and maybe the price? Thanks.
Mike
Strouty
Southern Maine
I think you are looking at displacement, not actual CFM, it should be about 25 CFM for a 7.5 HP motor. I had my hopes up that you had found some trick. Oh well, it will still be a nice compressor.
devoncoolman
quakertown pa
Lookin good. Taking $hit back and forth from work is for the birds.
MrAperture
Montreal, Qc
Had to help a friend do his wheel bearings on his e46 M3 so I bought the bearing removing set. This set is sooooo good, it saves you so much time. and got a fork set for ball joints because it was innexpensif.
I will also leave a 32mm 1/2 drive socket in there so I dont have to forget it if I do a job at someone else house.
ADSR
What bearing kit is that?
csmitty
No trick. Just going off the data sheet. There is what appears to be a Csp column as well which I took to be the measured CFM. Or maybe its standard pressure.
AA/FC
Bought the 1/4 drive wobble plus extension set, got the ratchet free.
Nele
Got a second cornwell toolbox, one in the living room, another in the bedroom, ha ha, se loves it!
