Fretters
Made a slight modification to that Fortis so that the spring is under slightly less tension. Seemed excessive the way they'd done it, and during reassembly, the original setup made it a cow to fit the front plate, whereas now the spring aids assembly slightly by closing the plate rather than pushing it open, as the end of the spring sits at the other side of the plate from where it was originally. I've literally just bent the end of the spring in the opposite direction and fitted a 2BA brass screw to act as a retaining pin and clamp.
The finished vice. Glad to finally get this one sorted. No major problems, but it's just been one of those pain in the **** type affairs to sort.
As it arrived:
Now:
The shade of green is actually slightly darker than it appears to be in the photo's.
As it arrived:
Now:
