technician117
Hey guys. I bought that QT-5 that I was looking at a few days ago. It's home and I'm getting it "hooked up". I got it wiped down and I added an outlet for it off of my garage panel. I bought a "whip" for a dryer plug so I can plug it in. My question is, how do I wire the 2 power feeds? The ground is easy. I've attached a pic of what I'm working with. Do I tie the black to the black, and hook the white (coming in from my cord) to the bottom screw?
Right now I have it hooked to a 30 amp breaker. Obviously once I run it I'll find out if it's enough, but what's the opinion on running it off a 30 amp?
This is my first compressor. When I was younger I ran my Dad's old Wayne compressor, but it was already outfitted... and outdated so I don't want to follow that set up if it's not the best way. So I'm looking for information on what I should buy to have this thing last me long term... ie, water traps, what else?
Next. I need a new air filter. Any recommended sources? I have the old one and the part number is legible.
I also want to change the oil in it. What should I run? I live in the northeast and my garage has heat, but only when I turn it on.
Anything else I'm missing?
Oh, and to confirm, this is an 80 gallon tank right?
Edit - background on me is I used to be a Ford technician for 4 years and have been working on cars and motorsports for 15+ years now. I have a large set of air tools that will be the main usage of this compressor. Anything from a 1/2" impact to a cut off wheel.
