concrete floor sealer
Astro-t
Pennsylvania
Looking for a concrete sealer for my garage floor. I have a 24x28 garage floor i just built with a concrete floor that was dyed gray.
A
Astro-t
Pennsylvania
A satin or semigloss. I dont want anything that will peal or flake in a couple of years. I just need something to seal concrete dust from floor and to protect it from oil leaks.
roosty
I would DEFINITELY recommend the 6600 from Legacy. I am doing my 1200sq ft garage with it. I had to do it in sections so i could store my stuff. I used a microfiber 3/8 nap roller. The first coat went on very light most likely because it absorbed into the concrete, not like a stain does, but there was some absorbtion. It darkened it up very nice. The second coat i made sure i used a good amount and rolled over the first coat in a different direction. Hardly shows any roller marks. I did see some areas where more liquid stayed on the concrete and where some areas where i backrolled where it picked up some material that started to already set. Again, I am very pleased with the way it turned out!
I used a floor machine with a black scouring pad and some degreaser. I scraped the floor with a floor scrapper and pressure washed all the residue out the garage door.
While i cannot speak to the durability or the longevity of the product, it does seem to hold really well to the floor.
Garage Flooring
Grand Junction, CO
My concrete guy is suggesting a sealer called Siloxane.
Anyone heard of it?
Any good?
That is an ingredient in many sealers, including products we sell and there are a lot of brand names. One common one is Siloxa-Tek (preferably 8505) or the TrueLock HD40. Both should be used with a densifier first, such as TL37
LegacyIndustrial
deerfield, IL
Anyone heard of it?
Any good?
The HD6600-mma sealer shown in Roosty's pic is siloxane rich. Siloxane affords the sealer much more resistance to salt-water, deicers, etc...
It is available in gloss, satin and matte. Colors too!
Shea
California
We did an article on the Legacy HD6525 MMA sealer a while ago which you can find here. It should help answer some of your questions. It's pretty much the same stuff as the 6600 I believe with the exception that the 6600 also has great protection against salt water, translate - road salts, which would make it a good choice for your neck of the woods.
